Cell Phones Logo
T
Thomas garvin Posted on Mar 08, 2017
Can the pocket juice work on an apple iphone 5
2 Related Answers
Anonymous
  • Posted on Nov 20, 2011
SOURCE: my apple iphone 3g
I already have aircel pocket Internet on my apple phone. But now it's not working even I have valid till next month. Please help me
  • 19187 Answers
  • Posted on Mar 08, 2017
SOURCE: Can I use the pocket juice with an iPhone 5
The reviews on that are bad, I would not waste your money
What HDMI cable do you use for a brookstone projector
https://www.projectorcentral.com/Brookstone_hdmi_pico_projector_review.htm
Pocket Projector
Mobile includes an HDMI® compatible cable, MHL cable, 5- to 11-pin adapter and AC adapter. To connect to any device without an HDMI® compatible port, you will need an HDMI® compatible adapter or Apple Digital AV adapter (sold separately). Your device: ... Apple® iPad®, iPhone® and iPod touch® devices.
Brookstone Pocket Projector - Good Dog Digital
Mar 08, 2017 • Cell Phones
2answers
How do I fix a broken iphone screen?
There is website called ifixit.com that has the front panel for the iPhone it is 65.00 and it is worth getting. Go to YouTube.com and search how to fix a iPhone front screen. Follow the instructions very carefully an have the right tools to take it apart. Also ifixit has the tools to fix the phone. Hope this helps you out.
2answers
Screen of iphone 5 randomly zoom in
You may have zoom enabled in the accessibility settings. You may want to try turning these settings off.
  1. Locate and tap on Settings > General > Accessibility:
  2. Tap Zoom and turn off using the slider:
Hope that helps!
My son spilled gatoraid onrange juice on my iphone 4s
If you have already tried using the iphone it might be too late to help. But I would try putting it into a bag of rice for a few days. Sounds dumb but it dries the iphone out. If it does not work after that its RIP Iphone 4S. Goodluck!
1helpful
2answers
I have had my iphone less than a week- i did not expect it to have problems so soon. .... i have iphone 2g my battery ran out now it wont recharge or turn back on? .... but it doesn't turn on, it...
If your iPhone's battery runs very far down, the iPhone won't turn on. That's because it's using its remaining battery life to preserve your data and settings.So, your iPhone could be refusing to turn on because its battery doesn't have enough juice. In that case, plug your iPhone into a wall charger or into your computer (plug it directly into the computer; some USB ports on keyboards don't have enough power to charge iPhones). Let it sit for 10-20 minutes. If it was low on battery and needed a charge, when it's got enough juice to power the screen, it will turn on and show you its charging status, starting with the red battery icon.During this process, you may also want to make sure there's no lint packed into your cable or the iPhone's dock connector. This isn't a hugely common problem, but a lot of pocket lint could interfere with the iPhone getting a charge.
8helpful
My iphone went dead. I hung up from a call and then went to use it again - dead. Plugged in for 1/2 hour and still no juice. Is there a reset button?
Charge your iPhone overnight. If that does not work, try the following resets:
If iPhone won't turn on, or the display freezes or doesn't respond
  1. Press and hold the Home button for at least ten seconds, until the application you were using quits.
  2. If that doesn't work, turn iPhone off and turn it on again. Press and hold the Sleep/Wake button on top of iPhone for 10 seconds until a red slider appears, and then slide the slider. Then press and hold the Sleep/Wake button until the Apple logo appears.
  3. If that doesn't work, reset iPhone. Press and hold the Sleep/Wake button and the Home button at the same time for at least ten seconds, until the Apple logo appears
  4. More resets:
Try This:
1. Remove Sim Card
2. Hold in 'Home' button and 'On/Off' button together until Apple logo appears
3. Replace Sim Card
4. Hold in 'Home' button and 'On/Off' button together until normal phone screen appears.
Also, Try this:
1.) Shut down the iPhone 3G.
2.) Start up iTunes
3.) Hold down HOME button on the iPhone 3G
4.) While keeping the HOME button depressed, plug in the Sync cable
5.) A message will pop up to ask if you want to reset.
6.) Just click YES and the reset process should start.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it and give a testimonial for my response
Thanks, Joe
I’m happy to assist further over the phone at https://www.6ya.com/expert/joe_8b8c2cd6ce148309
My apple iphone 3g
17helpful
2answers
My icons on ma iphone have magnified and i want them to go back to normal size?help pls...everything is soo large and i want it to be the way i baught it....small icons!
Hello Nanagruv,
Just tap 3 fingers at the same time on your iphone's screen. What happened was you unintentionally grabbed the iphone thru your pocket and had placed three fingers at the same time in the screen.
Please let me know if this works. Goodluck!
Cannot connect to youtube my iphone 3gs apple
Ultimate Video Download Studio helps you put any video format onto your iPod, iPod touch, iPod
video nano, iPhone, Zune, PSP, video capable MP3 players, video capable mobile
phones, and Pocket PC, etc.
Top Apple Cell Phones Experts
Grand Canyon Tech
Grand Canyon Tech
ADMIN Andrew
ADMIN Andrew
Paul Bade
Are you an Apple Cell Phone Expert? Answer questions, earn points and help others
