Question about Science & Laboratory
Error e61/p2-5b in euronda e9 autoclave what means?
Anonymous
SOURCE:
Anonymous
  • 185 Answers
SOURCE: Error message E9
gebje,
error codes on pentax camera's are in the repair manual to help the technician find the problem faster. e9 is shutter failure and will need to be repaired.
Posted on Dec 16, 2008
Joed911
JDTec
  • 4338 Answers
SOURCE: i have a SVC E9 error what does that mean
SVC E9 is an OPC Marker sensor error. Here is the service manual. See page 64 (or2-4 in the manual) for troubleshooting steps:
http://transfer.barrister-net.com/download/Lexmark/Color%20Laser/Lexmark%E2%84%A2%20C500n%205023-110.pdf
Click on this link or copy and paste the complete link into your browser.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
I’m happy to assist further over the phone at https://www.6ya.com/expert/joe_8b8c2cd6ce148309
Posted on Jan 03, 2009
blueextc3221
blueextc3221
  • 15935 Answers
SOURCE: On Power up the error code E9 displays with a continuous beep
F9 is an Overflow Condition error. If the Overflow contact on the pressure switch is closed for more than 60 seconds an Overflow condition will occur. In an Overflow condition, the Door may remain locked, and the Drain Pump may run constantly, even if PAUSE/CANCEL is pressed twice and the Display is cleared. Unplug the unit to service. You will need to check to following:
1. Check the drain hose and make sure it is not plugged or kinked.
2. Check Wire Harness connectors to the Drain Pump, Pressure Switch, and Central Control Unit (CCU).
3. Check/Clean Drain Pump Filter of foreign objects
4. Check for Drain Pump Failure.
5. Check the Inlet Valve for proper shut off
6. Check the Pressure switch for proper operation.
1. Check the drain hose by removing it from the standpipe and pull a vacuum on it with a shop vac. It could be that you have an obstruction somewhere. You may have to check the drain pump and the drain hose just prior to the drain pump as well. This is the hose that attaches to the bottom of the tub. This area can get clogged with debris
2. Unplug the washer and remove the kick plate and top panel. Check for any loose connections at the drain pump, pressure switch (located in the right rear of the machine), and the CCU (located in the center rear of the washer behind the wash tub). You may have a loose or dirty connection somewhere. If you remove any connectors, make sure you write down where they go. It's best to only remove ONE connector at a time when checking the CCU. On the pressure switch, make sure the air hose is still attached. This is usually a clear or black rubber hose. With the air hose off, loose, or leaking, the switch will not work and the tub will continue to try to fill. The pressure switch can be checked by removing the the large connector plug from the front of the CCU at the very LEFT. Readings across pins 1 to 2, 3 to 4, 4 to 5, and 4 to 6 should ALL read 0 ohms.
3. The drain pump. Remove the clean out cover on the pump and check for debris. Make sure you drain the water from the drain lines, pump and hoses PRIOR to removing the cover. Otherwise, you will have about a gallon or so of water to clean up. The shop vac method works great for this. If the pump is running and clear of foreign matter, the pump is probably not the problem. A meter reading across the pump motor windings at the connector plug should be about 15 ohms.
4. The inlet valve. If the inlet valve would fail in this manner, the tub would be trying to fill with water all the time and not shut off (even with the washer turned OFF). You need to ask yourself if you find standing water in the tub when not in use. Replace the water inlet valve if this is the case. Readings across the HOT and/or COLD solenoids should each read about 800 ohms.
5. The suds error. This occurs when air from too much detergent gets into the drain line. If you are using HE detergent (which is great, because on the newer models NOT using HE detergent voids your warranty), but HOW MUCH are you using? Some things to consider:
a. Do you have soft water? This can actually cause the soap to suds better making the need to cut back on how much you use.
b. Look at the detergent container. Is it double or triple concentrated? Some detergents are sold as extra concentrated which means you need to cut back on the amount you use. Not doing so can cause the water to over suds.
c. What size loads are you using the detergent in? Running small loads with the same amount of detergent can also cause over sudsing.
Rule out the simple common sense things first. If everything else checks out and your problem still persists, you may have a failed CCU or pressure switch
Posted on Sep 12, 2010
buddika131
buddika131
SOURCE: E9 error means what
what is meaning of E9 ?
Posted on Apr 20, 2013
AJIN G
Electro Med Services
  • 6694 Answers
SOURCE: Error code e9
If you wish to get some details; check the site linked here. Pull up older posts.....
http://electro-medical.blogspot.com/
Posted on Apr 28, 2016
Hello, does anyone recognize E61 error code for Euronda E9 autoclave please?
The error E61 indicates that your water pump has failed or is not active. You should check the pump and replace it if needed. You should also check the steam generator sensor and replace it if needed.
For more information, contact Euronda at Water inlet pump inactive or call (+39) 0445 329811 (Vicenza, Italy)
Jan 08, 2018 | Science & Laboratory
Errors in euronda autoclave
http://www.euronda.com/contacts.aspx
Feb 10, 2014 | Science & Laboratory
What errors?
More info needed.
Jan 30, 2014 | Science & Laboratory
latoclave ecrire alarm e27 et la porte ne pas ovrire
Jan 22, 2014 | Science & Laboratory
It could be several problems.
Jan 21, 2014 | Science & Laboratory
7 whenI have autoclave Euronda E switch on , an error say no power supply ... any solution please ?
See if voltage is available to the unit. If so,. Replace the power supply within the unit itself.
Dec 08, 2013 | Science & Laboratory
Errors in euronda e5 autoclave
What is the alarm?
What phase of the cycle are you getting your alarm?
Oct 31, 2013 | Science & Laboratory
You have a leak. verify door seal; some valvs; pump damage or you have obstruction in some tube...
Jul 02, 2013 | Science & Laboratory
Science & Laboratory Logo
1,181 people viewed this question
Top Science & Laboratory Experts
Pokinhas
Tom Chichester
Are you a Science and Laboratory Expert? Answer questions, earn points and help others
