Error code E9F came up on my FFFW5000QW0 Frigidaire front load machine. I changed 4 parts inclusive of the door lock and still stuck on pause. I changed the motor, control, circuit board and wire harness
SOURCE: Washing Machine starts, squirts water, then stops.
E5E IS FOR Communication problem. THERE IS 100 %WIRE SHORTING SOMEWHERE.PLEASE CHECK OUT.
ALSO OTHER ERRORS
Error code - Fault condition
E11 Fill time too long.
E13 Water leak in tub or air leak in air bell.
E14 Reed switch.
E21 Water not pumping out fast enough.
E23 Drain pump relay on control board failed.
E24 Drain pump relay on control board failed.
E31 Better models. Pressure sensor not communicating with control board.
E35 Better models. Pressure sensor indicates water overfill.
E41 Control board thinks the door switch is open.
E42 Door remains locked after cycle is completed.
E43 Control board problem.
E44 Control board problem.
E45 Control board problem.
E46 Control board problem.
E47 Board thinks the door PTC circuit is open in spin.
E48 Board thinks the door PTC circuit is closed.
E52 Bad signal from tacho generator.
E55 Motor overheating.
E56 High motor current.
E57 High current on inverter.
E58 High current on motor phase.
E59 No tacho signal for 3 seconds.
E5A High temperature on heat sink.
E5B High temperature on heat sink.
E5C High temperature on heat sink.
E5D Communication problem.
E5E Communication problem.
E5F Communication problem.
E67 Input voltage on microprocessor incorrect.
E75 Better models only. Water temperature sensor circuit.
E76 Better model only. NTC temperature for the cold water valve over the limits.
E95 Communication error.
EB1 Incoming power frequency out of limits.
EB2 Incoming line voltage above 130 VAC.
EB3 Incoming line voltage below 90 VAC.
EF1 Clogged drain pump.
EF2 To much soap.
SOURCE: what are parts numbers for frigidaire front load
Hi
The door latch Part 1191127 is at this link
http://www.repairclinic.com/Appliance-Parts?s=t-ATFB6000ESO-%3d%3dc226
Motor Control Board Part 1191307 here
http://www.repairclinic.com/Appliance-Parts?s=t-ATFB6000ESO-%3d%3dc212
Hope this helps. Please do rate this answer. Thanks.
SOURCE: Frigidaire Front Load Washer won't Spin
i fixed mine about 5 times and its always some thing diffrent.
try buyng the inexpencive parts first and leave for last the electronic control panel.
it could be that your washing a smaller amount than the recomended.
Take it to a profesional. dont do like me a DIY guy. Some times i need to take pictures when taking the monster appart and then because they are somany screws missing duct tape, rope or hangerwire becomes usefull.
All mechanics are wise guys you and me are thevictims.
SOURCE: Frigidaire machine error codes E5E and Error Code 59
OK, I had an awful unbalanced load that was banging like crazy for about 5 seconds before we hit cancel. After that the machine wouldn't rotate at all in any cycle.
After opening it up and checking the belt, I found a wire harness just siting there unconnected. Now sometimes machines have unused harnesses but clearly this had to be it. In my case it was a 5 wire harness coming from the top of the unit (control panel).
It turns out this was knocked off the motor control circuit board from the motor banging around. I could see impact marks on the white plastic housing of the control board.
From the back, undo the one screw on the L bracket holding the white housing in place. Then gently ease the housing around the motor just so you can access the top better. You won't be taking it out, just twisting to a better angle (you can, but no need to disconnect all the other wires). Lift the housing lid and you will see a another wire harness on the right side next to the green ground wire that goes to the motor. The loose harness goes right on the circuit board edge - you are not looking for pins to connect to like most harnesses you may be used to. You will see an indent for this 5 wire harness in the middle of the circuit board, so snap it over with wires towards motor. Close up the lid and reinstall the white housing back into place, making sure to get the leg clipped under the sheet metal on the front side.
One important note - the circuit board map on the printed troubleshooting sheet says this hardness goes on J3, but the correct spot on the circuit board says J2. J3 has 7 connection points and is actually not used. Nice one Frigidaire.
I actually did this twice because the first time it didn't work. The second time I just made sure I pushed ALL the connectors I c ould see in nicely in case there was a bad connection. And that did it. the machine and works fine.
Mine was a Frigidaire LFT2140ES3, but I woudn't doubt that this could happen to other models.
please see the causes with common sense, before to proceed to exchange some error parts. God bless you
Water Level Control / Pressure Switch
his is the most common reason a washer will agitate but not spin. To
check this on most , with no water you should have continuity on pins
7&15. With the tub full 7&16 should have continuity. This video
walks you thru checking another type of switch.
Lid Switch
This can be the problem for the washer not spinning . Most whirlpool
styles this will effect both agitate and spin but some models will still
agitate but not spin.This is easy to check. You will need to remove the
switch, this varies with model type but the testing will be the same.
When the lid is closed the switch should have continuity when the lid is
opend the switch should have no continuity. If it differs replace the Lid Switch.
Timer
To check the timer you will need to refer to the wiring diagram or
disassemble to access the motor. Check the leads from the timer to the
motor when turned to a wash cycle this should have 120 volts. If not replace the Timer, if it does the timer is not the problem.
Motor
To check the motor you will need to disassemble the washer
to access the motor. First you can check the motor windings, to do this
remove the plug and connect ohmeter to terminals. Refer to the tech
sheet or service manual for the proper reading. Check motor for shorts
by connecting ohmeter to terminals and motor housing should have no
continuity. Connect voltmeter to motor wire connector and check for
voltage. You should have 120 volts, if you do and the motor does not run
replace the motor. If it does not have power the problem is elsewhere.
Belt
If your washer is a belt drive type make sure the belt is tight. Check
for black soot from belt wear. Replace if it has excessive wear or
broke.
Motor Coupler
This is a fairly common problem with direct drive machines but
inexpensive and easy to replace. The Motor Coupler transfers power from
the motor to thetransmission. The following video will walk you through
the replacement of the Motor Coupler.
Transmission
The transmission does not usually fail. To check this on a direct drive remove the motor
and then turn tub inside. If it spins freely with no noise theproblem
is elsewhere. If it is noisy it needs replacing this is expensive and
depending on the age of your machine you may not want to replace it. On a
belt drive remove the belts and spin tub.
Hello - Typically error code E9F indicates a communication problem. A certified technician will need to check the wiring between the main control board and the speed control board. Depending on the diagnostic either the wiring, main control board or speed control board would need to be replaced. Contact a professional to move forward accurately.
Hi
PAU is short for pause; the machine detected something wrong so it paused itself. Unplug it from the wall for a minute and plug it back in, it may reset. Once you plug it back in, it should display a Numerical code. You need to find out what's that error code mean.
Please get back to us if you have further query else please accept the suggestion.
Thank you for contacting fixya.com
