Question about Kyocera FS-1028MFP Mono Multifunction Laser Printer
Hi, I have an error code C7990 on a Kyocera FS-1028 MFP. Can someone help me on translation and fix of this error?
    Champion:
    New Friend:
  • Kyocera Expert
  • 250 Answers
Empty drum unit its full of waste toner each side of drum unit has plastic covers that pop off empty out the unit thoroughly and vacuum inside
Posted on May 04, 2017
6ya staff
SOURCE:
Anonymous
  • 56 Answers
SOURCE: Kyocera FS-2000D
Hi, Sound like drum unit is out off position.
Switch off printer.Open left side door, remove waste toner bottle and push drum unit(with grej lever on it) in printer to proper position.If grey lever is not in proper position, drum will be not locked.Place waste toner bottle in position.Switch on printer.
Posted on Nov 06, 2007
Anonymous
  • 38 Answers
SOURCE: KYOCERA CS-1820 ERROR CODE C7990
Apologies for the late reply. This is a waste toner full problem. Pull out the process unit (in case you don't know, it's the big black unit where you fit your toner into, also the one that you need to remove to check for paper jams. Turn it around so that the side where the toner fits is furthest away from you. Now on the side closest to you, on both the left and right hand side are two small covers, each fastened with 1 screw, hidden in deep holes. Remove these screws and covers, and empty the toner inside.
Be advised that this is a very messy job. Also, after you've removed these covers and you turn the unit on its side, the toner may not fall out. in this case stick a screwdriver or something in there to loosen the toner.
When done, refit the covers, place the unit back into the machine, restart the machine, and thats it. If the code still appears, you've got toner on the waste toner full sensor, which sits just above where the waste toner part of the process unit is, inside the machine. you can take a cloth and wipe this. although this is highly unlikely, nothing in this industry surprises me anymore.
if this still fails, you could have a faulty sensor or circuit board, but again, highly unlikely
have fun (nothin like gettin your hands dirty) ;)
Posted on Sep 18, 2008
Anonymous
  • 40 Answers
SOURCE: Error C6000 is showing, can you tell me if I can fix myself or call for service.
In some cases you can reset the C 6000 - when is a false error.
try this:
1. Go to Menu/System and browse till you see
"Service".
press and hold: # START ENTER
The "Service" will go away and browse to "Maintenance".
2. Press ENTER to go in maintenace mode - the display change to Maintenance mode.
3. browse to 0163 and press ENTER - reset fuser
4. pick EXECUTE and press ENTER
5. turn the copier OFF, wait 20 seconds and power up the machine.
If C 6000 goes away it was a false error if NO ...try again and if the C6000 persist means the thermal fuse it is blown so you have to replace the fuse = call for service.
Posted on Jan 12, 2009
Anonymous
  • 66 Answers
SOURCE: I have a FS-1118 MFP
yyou have to be careful when doing this.
the waste toner is built in to the process unit (drum unit) and has a plug on the side.
remove the plug and tip it out.
Posted on Mar 10, 2009
Sheri McMichael
  • 241 Answers
SOURCE: kyocera fs-3900dn showing 7410:0024216 error code
The 7410 is a drum installation error code. This is typically caused when the waste bin is replaced. Open the left door and push on the drum unit just above the waste bin, usualy a click will be heard when pushing it in. Then power cycle the printer. This should fix the error message.
Posted on Jun 09, 2010
How i do fix code error 245 for kyocera 6525 MFP
Upgrade to the latest firmware of the FS-6525MFP.
Oct 20, 2014 | Kyocera 6525 Copier
ERREUR MACHINE CODE C7990
Drum waste chamber needs emptying or drum unit replaced.
May 25, 2014 | Kyocera Mita Kyocera FS-1028 MFP Laser...
Kyocera fs-1028 mfp machine failure call service c7990
its a waste toner error put a new one in if the error persist check all the sensors you may also have to replace the drum
May 21, 2014 | Kyocera Office Equipment & Supplies
Repair kyocera fs-1028 mfp machine failure call service c7990
developer unit fitted correctly or failure of developer unit .
May 21, 2014 | Kyocera Mita Kyocera FS-1028 MFP Laser...
How to reset a process unit
Make sure that the front and top covers close smoothly and fully. If the blue toner release arm is not fully to the rear the top cover will barely close. To reset the process unit you should remove it and then re-install it making sure it makes a good 'click' when you insert it.
Apr 15, 2014 | Kyocera Mita Kyocera FS-1028 MFP Laser...
The waste toner container is located inside the drum unit.This code means the drum unit is full. To empty there are two caps that can be opened and the waste toner can be emptied. Usually the waste gets full when the unit is very close to be replaced. You may be able to get some more time if you empty it, but you will probably need to replace the unit soon.
Nov 12, 2013 | Kyocera Mita Kyocera FS-1028 MFP Laser...
Kyocera FS-1028MFP Mono Multifunction Laser Printer Logo
2,014 people viewed this question
Top Kyocera Office Equipment & Supplies Experts
Tareq Bin Mostaq...
Tareq Bin Mostaq...
CheckitRight
CheckitRight
Marvin
Marvin
Are you a Kyocera Office Equipment and Supply Expert? Answer questions, earn points and help others
