SOURCE: remote not working tv
Try this website -1-800-Remotes Factory original for an original remote.Small companies tvs,or contract tv universal codes are usually limited,best buy an original remote.
SOURCE: i was switching my ps3 from hdmi output to the
Easy to fix so don't worry ;)
While the PS3 is off (solid red led)
Hold down the power button until you hear the SECOND BEEP, quickly release.
This will reset the video settings back to default.
SOURCE: brand new dmr-ez49veb,has worked ok on setting it
i have a panasonic dvd rcorder / video combi model DMR-EZ49VEB. I have recorded something on DVD, which is 4 hours in duration, and I want to edit the recording and split it into parts. I follow the manual, but when I press EDIT the option to split isnt even there? I am confused, it is SUCH a difficult manual to deciphre, but the only 2 options there are "Edit title name" and "Change Thumbnail". The others are not listed. the disc is not copy protected or locked and is of sufficient duration to split the contents. HELP PLEASE :(
SOURCE: i have a 32inch goodmans flat screen tv the remote does not work
Have the remote checked--it can be tested to see if it is the
problem--if remote is good but does not work on set the remote receiver
may be bad inside the TV.
Most shops and some electronic places
have a remote tester--point remote at it and press the buttons and if
working a light reacts---some digital cameras will also if on react on the little screen they have if this is done.
Either the remote or the receiver in the set is most common.
