SOURCE: moving apps onto sd card
Hi in order to move apps to sd card you need place the sd card in your tablet go to settings then applications. On the next screen you've got the list of downloaded apps just clik on one of them and then properties screen come up on which in the second row you will see button move to sd card. Just press on it wait few seconds and your apps is moved. Repeat this for every app but bear in mind that some of the apps can't be moved to sd card Regards
SOURCE: how do I reinstall the play store app on my samsung galaxy 10.1 tablet
Hi there . I would suggest going on Google and try typing in play store and download it from there if there is an option . Or if you go into settings and find the factory reset you would most likely be able to get it back with a full reset . Be sure to back up first
go to settings --- application---uninstall, remove app data
OR
you can reset but data will be lost
SOURCE: How do I recover Google apps and play store to my Samsung galaxy tablet 2, after factory reset,
Go and search it on the Play Store and manually install it.
If it fails try searching on google for an apk of google services and install it on your device.
Looking at the specs for both, they have USB 2.0 and they both accept microSD memory.
Depending on the format of the B&H memory, it may plug into the Galaxy 3 and be recognized.
Or, if that doesn't happen, you can safely connect the two via USB cable although you may need different cable ends or an adaptor for one or the other but these will be available anywhere accessories of that kind are sold.
Good luck-
