My Crosley CAW8350EW1 wash machine just stopped after the last spin cycle drained and the spin light keeps flashing. I'm wondering if that would be the timer or something else?
Re: My Crosley CAW8350EW1 wash machine just stopped after...
Make sure that it didn't stop because of an unbalanced situation
as it is draining it should be turning slowly and as soon as it empties the spin speed picks and and the unbalance stops the machine
It wont start up from there at all. I tried to start it back up with no luck. It is empty.It wont start up from there at all. I tried to start it back up with no luck. It is empty.
Can't remember the exact error code, but my crosley front loader would not spin. I found out this was because all the water was not being pumped out. I wash a lot of dog blankets and found out the drain basket was completely blocked. I was able to remove and clean from the back and this fixed my problem. I guess it could be the pump but check this basket first. The way I did it from the back was hard so I suspect there is a better way to access the basket.
I would check the water pump for a blockage, there could be something in the pump preventing it from doing its job as the machine cant go to the next cycle until the water has been expelled before the machine can continue eric
Washing machine stops at the spin cycle - light flashes. Have to drain water out manually. Happened last week and was then able to run an empty rinse cycle. Machine worked normally for another week. Same problem today but have had to drain water manually from the drum after trying an empty 90 wash and rinse cycle (both stopped on the Spin and flashed). Any ideas? Thanks. x
