Unable to ef???????
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/normanj_7893313f0751935f
SOURCE: konica minolta pagepro 1350w error light won't stop flashing
pleas install status monitor, it will tell you what is wrong
SOURCE: konica minolta 1350w status display comes on at start up
Open c:\windows\system32
find a file called MSTMON_Q.EXE
right click and rename the file to anything with a file extension .exe, I named it MSTMON.EXE
Create a shortcut to this new file in case you need it in the future and put the shortcut on your desktop
also, write the original name of the file down or put it on notepad, in case you want to change it back.
restart windows
SOURCE: konica minolta pagepro 1400w paper jam
have you tear the paper when removing? there is a small paper left still inside the paper path. open the back side and the top part and check for small paper. I hope that will solve your problem and if think the problem still there the problem is one of the paper sensor actuator is broken or out of place.
SOURCE: konica minolta pagepro 1350w fatal print spooler
A 'print spooler' is a range of memory either internal to the printer (sometimes called 'buffer memory') or set aside from the RAM in your system.
A fatal error normally means the material you tried to print has been lost and must be sent to the printer again.
If the error continues to show up, you may have bad printer memory or perhaps the driver software in your system has gotten stepped on by the operating system and needs to be reinstalled.
Windows loves trashing files to keep life exciting.
This problem is not related to the drum or toner cartridge.
