Question about Sansui Televison & Video
How to connect dstv decoder wires(cables) to sansui plasma
4 Suggested Answers
6ya staff
SOURCE:
Anonymous
  • 12 Answers
SOURCE: Need to connect my DSTV decoder through my sony
well this is easier than you think, get yourself a set of RCA's (the red and white and yellow cables that DVD players come with) look behind your decoder and place them colour to colour, then behind your Amp you will read (TV IN) do the same, then with just one yellow RCA plug it into (monitor) that one will then go to the (AV input) behind your TV.. And presto!!! now set your amp input on the remote to TV and your off!! good luck
Posted on May 03, 2010
dunnbiker
David Dunn
  • 8546 Answers
SOURCE: I HAVE A LG 42
Search for the manuals and read them.
Retrevo.com
Posted on Feb 21, 2011
0731596049
0731596049
SOURCE: I'm not able to connect
  • i cant connect my standard decoder to samsung 51inch as ther are only ports compements and hmdi,do i need a pvr decodr?
Posted on Dec 09, 2012
How to connect optical cable from dvd to amp and to tv i also have a dstv decoder
All of our devices have to have toslink plugs for those cables to work. If not, you will have to get all sorts of adapters. PIA
Sep 22, 2017 | iHave Audio Players & Recorders
I'm not able to connect my dstv decoder and dvd player onto my samsung 51"plasma tv because there's only one AV plug. Can you please help?
Jul 12, 2011 | Televison & Video
Can't pick up signal on the other room for my dstv
chances are your problems lie with your connections themselves, most cases its with the splitter box if you are using one, if u are then rather remove the splitter box altogether, u will then need a set of RCA cables (the red white and yellow cables that come with DVD players) use these to connect the first point directly from the decoder to the TV using a free AV input behind the TV. form then on proceed to connect the cable going to the room directly to the RF OUT port behind the decoder (make sure the copper and aluminium wires dont end up touching, but use both, the copper on the inside and the alu on the steel outer casing) if this doesnt work check your connections and if all fails replace the cable as a last resort
Oct 08, 2009 | LG DR787T DVD Recorder
Need to connect my DSTV decoder through my sony amplifier (5.1) not sure of a the cabling or the connections, does someone perhaps ahve a wiring diagram to connect TV, dstv decoder and sony 5.1 amplifier?...
Jun 29, 2009 | Fujitsu Siemens PlasmaVision P42VHA40...
Black and white dstv
look on the TV menu for (system) in south africa we use PAL, if you cant change it on the TV, with the decoder remote press menu then 7 then 4, it will ask for a pin code press 9-9-4-9 it will read "RF modulator" press OK, it will then read 1 MODULATION press ok again and it will highlight PAL I now press the right key and press OK, if this persists then the decoder it probably faulty... good luck
May 28, 2009 | Sony KP-EF61 61" Rear Projection...
Sansui 42'' HDMI problem
howto get the hdmi signal thro hdmi to dvi cable in plasma pdp42 sansui tv in dvi input
May 03, 2009 | Sansui HDPDP4200 42 in. HD-Ready Plasma...
Televison & Video Logo
327 people viewed this question
Top Sansui Televison & Video Experts
matt martin
matt martin
Ekse
Are you a Sansui Televison and Video Expert? Answer questions, earn points and help others
