Televison & Video Logo
William Simba Brown Posted on Mar 17, 2017
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
My element tv is not allowing me to adjust the color, tint, or sharpness. What do i do? My tv's picture looks like an oil panting
shaun taylor
Level 3:
  • Element Master 1,527 Answers
  • Posted on Mar 18, 2017
shaun taylor
Element Master
Level 3:
Answers
1527
Questions
0
Helped
338235
Points
3957
Hi sounds like the picture is solarised, this would be down to a tcon board fault, thanks
shaun
1helpful
My new tv when I hit menu and try to adjust the color.The tint will not come up?
If you are using an HDMI source for the video, you might not be able to control certain video/color settings as they are determined by the video itself.
You may be able to change mode on your TV to 'gaming', 'movie', 'sharp'...
1helpful
My 19 in. is not possible to adjust the color, tint and sharpness bars. It skips, what will I do to make the adjustments?
If the set is running in some type of component mode or digital component mode, there is no adjustment for color or tint.
How do you adjust the tint on the element tv?
On NTSC system tint option available. Use NTSC system TV channel and adjust the tint of colors. This option is not available in PAL / Se cam standard.
1helpful
LOOKING FOR PICTURE SETTING SAMSUNG MO.NO.LN-T5265F
This may help you...you can also get an owners manual free on line.
English - 23
Using Automatic Picture Settings
Your TV has Three automatic picture settings ("Dynamic", "Standard", "Movie") that are preset at the factory.
You can activate either Dynamic, Standard, Movie by making a selection from the menu.
1. Press the MENU button to display the menu.
Press the ENTER button, to select "Picture".
2. Press the ENTER button to select "Mode".
Press the ??² or ??¼ buttons to select the "Dynamic", "Standard", "Movie" picture
setting. Press the ENTER button.
?³ Choose Dynamic to increase the clarity and sharpness of the picture.
?³ Choose Standard for the standard factory settings.
?³ Choose Movie for a natural Image without picture enhancements.
3. Press the ??² or ??¼ buttons to select "Contrast", "Brightness", "Sharpness",
"Color", or "Tint(G/R)", then press the ENTER button.
4. Press the ??? or ??? buttons to decrease or increase the value of a particular item.
For example, if you select "Contrast", pressing the ??? button increases it.
Press the EXIT button to exit.
• When you make changes to Contrast, Brightness, Sharpness, Color, Tint(G/R)
the OSD will be adjusted accordingly.
• When in PC mode, Tint, Sharpness, and Color are not available.
Press the P.MODE button on the remote control repeatedly to select the desired
picture mode.
Picture Control
Move Enter Return
Mode : Dynamic ???
Contrast 1 00
Brightness 50
Sharpness 85
Color 55
Tint G 50 R 50
Balck light 1 00
??¼More
TV Picture
Move Enter Return
Mode : Dynamic
Contrast 1 00
Brightness 50
Sharpness 85
Color 55
Tint G 50 R 50
Balck light 1 0
??¼More
TV Picture
Dynamic
Standard
Movie
Move Enter Return
Mode : Dynamic ???
Contrast 1 00
Brightness 50
Sharpness 85
Color 55
Tint G 50 R 50
Balck light 1 0
??¼More
TV Picture
50
??² Con trast ??¼
Move Adjust Return
English - 24
Adjusting the Color Tone
You can change the color of the entire screen according to your preference.
Press the ENTER button to select "Picture".
2. Press the ??² or ??¼ button to select "Color Tone", then press the ENT ER button.
3. Press the ??² or ??¼ button to select "Cool2", "Cool1", "Normal", "Warm1",
or "Warm2".
When the picture mode is set to Dynamic or Standard, Warm1 and Warm2
cannot be selected. Movie mode is only available.
Move Enter Return
??²More
Color Tone : Cool2 ???
Detailed settings ???
Size : 16 : 9 ???
Digital NR : Low ???
Active Color : On ???
DNle : On ???
Reset : OK ???
TV Picture
Move Enter Return
??²More
Color Tone : Cool2
Detailed settings
Size : 16 : 9
Digital NR : Low
Active Color : On
DNle : On
Reset : OK
TV Picture
Cool2
Cool1
Normal
Warm1
Warm2
Activating Backlight
You can adjust the screen brightness by adjusting the LCD backlight brightness. (0~10)
2. Press the ??² or ??¼ button to select "Backlight", then press the ENTER button.
3. Press the ??? or ??? button to decrease or increase the valueof the backlight
brightness.
Move Enter Return
Mode : Dynamic ???
Contrast 1 00
Brightness 50
Sharpness 85
Color 55
Tint G 50 R 50
Balcklight 1 0
??¼More
TV Picture
5
??² Balcklight
??¼
Move Adjust Return
Move Enter Return
??²More
Color Tone : Cool2
Detailed settings
Size : 16 : 9
Digital NR : Low
Active Color : On
DNle : Off
Reset : OK
TV Picture
OK
Cancel
Resetting the Picture Settings to the Factory Defaults
1. Press the ??² or ??¼ button to select "Reset", then press the ENTER button.
Press the ??² or ??¼ button to select "Cancel" or "OK" then press the ENTER button.
Each mode can be reset.
1helpful
Yellow tint no color red.
you can adjust in color mode. please balance the tint, color,brightness, contrast, & sharpness.
Color
see if there is a "default" option, if not set everything back to the middle, if the colors are still off you sure its not the convergence?
most big screens allow you to change "color temperature" it's like a default adjustment for 3 different brightness levels.... ie...COOL, WARM picture will show obvious changes in brightness
Adjusting to the proper color
Tint would be the control that will control the color balance, but this sounds like it may be deeper then that. Turn your color all the way down so that you have a black and whit picture. If the picture is still yellow then you have a problem with the blue picture tube.
1helpful
A lot of green tint in the picture
Hi, what you do is unscrew and take off the grill, take off the black board behind it. You will see a little box for adjusting RGB you will adjust the screen rgb to get the tint to go away and have a perfect color then you will adjust the focus for sharpness. (reset the tv to factory settings before doing this so that your tint, color, brightness and everything else is in the middle.
2helpful
2answers
Picture settings
Colorimetre HCFR software
AVC HD 709 calibration disk
Spyder2 colorimeter (I know most prefer the Eye-One meters, but the Spyder2 was available from my job at no cost)
Here are the settings:
PS3 Blu-Ray player
Output Format (HDMI): Y Pb/Cb Pr/Cr (important!!! NOT RGB output)
BD 1080p 24hz Output (HDMI): On (this TV can reproduce video at 48hz for accurate 2:2 pulldown)
Y Pb/Cb Pr/Cr Super White (HDMI): On (not sure if this matters)
42LG50 Settings
Aspect Ratio: Set By Program (Personal Preference)
Picture Mode: Expert 1
Backlight: 50 (Personal Preference)
Contrast: 54
Brightness: 54
Sharpness: 40 (Personal Preference)
Color: 50
Tint: 0
Fresh Contrast: Off
Noise Reduction: Off
Gamma: Medium
Black Level: Low
Real Cinema: On
White Balance: Warm
Method: 10 Point IRE
10 (-3,8,-16)
20 (15,24,-21)
30 (20,36,-22)
40 (3,19,-40)
50 (8,34,-41)
60 (10,50,-20)
70 (-5,50,-8)
80 (-16,50,18
90 (-14,50,30)
100 (-22,38,21)
Red Color: -3
Red Tint: 0
Green Color: 10
Green Tint: 0
Blue Color: 14
Blue Tint: 0
Yellow Color: 0
Yellow Tint: 1
Cyan Color: -11
Cyan Tint: 0
Magenta Color: 0
Magenta Tint: -2
Take time to get used to the settings, you may think the screen looks dull at first. The truth is most people have way too much contrast on their TVs.
These settings will also work for Cable or Dish hookups, in which case you may change the Noise Reduction option to Medium to reduce signal noise.
OR....
2POINT IRE
Backlight: 65
Contrast: 55
Brightness: 45
Sharpness: 50
Color: 45
Tint: 0
Fresh Contrast: Off
Gamma: Medium
Black Level: Low
Real Cinema: On
White Balance: Warm
Method: 2 Point
Red Color: 3
Red Tint: 0
Green Color: 9
Green Tint: 2
Blue Color: -1
Blue Tint: 0
Yellow Color: 6
Yellow Tint: 5
Cyan Color: -1
Cyan Tint: 1
Magenta Color: 2
Magenta Tint: -1
1helpful
Recommended best settings for the TH-50PZ700U Plasma TV
Try this one and see if you like it!
Normal: No
Picture mode: Custom
Picture: +22
Brightness: +9
Color: -3
Tint: 0
Sharpness: 0
Color temp.: Warm
Color mgmt.: Off
C.A.T.S.: Off
Zoom adjust: (grayed out)
PC adjust: (grayed out)
-- Other adjust menu
Video NR: Off
3D Y/C filter: Off (grayed out)
Color matrix: HD (grayed out)
Block NR: Off (grayed out)
Mosquito NR: Off
Black Level Light
3:2 pull-down: On
HD size: Size 2
Top Element Televison & Video Experts
matt martin
matt martin
Are you an Element Televison and Video Expert? Answer questions, earn points and help others
