SOURCE: Ricoh Aficio SP C210 error message
Try loading letter size paper in tray1 .. Open the front door and the assembly attached to the front door is the transfer roller ASM. mybe you knocked it out of position ..There are green plastic clips that allow someone to the transfer roller unit so its easy to mess up good luck
SOURCE: Ricoh Aficio SP C410DN toner error.
Did you follow the instuctions to shake gently then remove all tags prior to placing the toner? Is it a toner/drum unit. look underneath if theres a green drum. After market toner will not work.
SOURCE: Ricoh SP C811DN error sc549
unplug printer, wait minute, plug in, should reset.
check Ricoh website to trouble shoot if does not reset.
SOURCE: how long will a ricoh sp 8100 run with a replace
On most similar Ricoh models, the "replace PM kit" message will keep flashing until the PM kit is replaced, but this shouldn't hinder operation at all. The machine will keep running until one of the parts breaks down, which depends on how old everything is and how hard it is worked.
Basically, the flashing message is a reminder to replace the maintenance kit as a preventative measure, but it does not NEED to be done until something actually breaks.
SOURCE: RICOH SP C222SF SC300ERROR WHAT IS IT. CAN IT BE
SC300 on a C222SF is a high voltage power error. You could reseating the connectors for the high voltage power supply and the engine board (EGB), but more than likely one of those two boards will need to be replaced.
