SOURCE: HI i am lookin for manuel of ipod model A1320
This should be the manual you are looking for. http://manuals.info.apple.com/en_US/iPod_nano_5th_gen_UserGuide.pdf
SOURCE: deblocage ipod nana model A1320
pour débloquer l'ipod, ya deux moyens : le premier : appuyer 10 secondes sur le bouton central et en meme temps le bouton menu et la le logo apple va s'afficher
si le problème persiste, il faut brancher l'ipod au pc, ouvrir Itunes, aller dans le menu ipod puis restaurer
SOURCE: hi i am having the
Hi nalotita47...
According to Apple, if you have forgotten the code, you can unlock the IPod by doing the following:
Connect your IPod to the primary computer you use it with (the first one IPod synced with), and open iTunes.
When you disconnect iPod from the computer, it will no longer be locked.
If you can't unlock IPod using either [the code or connecting it to the computer you use to manage its songs]. . . you can restore your iPod to factory settings using iPod Updater. Please note that this will erase all data on your iPod.
Afterwards, you can add your music and data back to your iPod.
If you want to change the primary computer that your IPod is associated with, do this:
1. Restore your iPod. WARNING: The restore process cannot be undone.
All of your songs and files will be deleted. Always make a backup of your important data.
2. Connect your iPod to the computer that you want to be the primary computer.
3. Open iTunes and synchronize.
Apple also notes that company "representatives cannot unlock an iPod if you forget your combination. If you can't unlock your iPod and you don't have access to the primary computer, your only option is to restore the IPod, which will erase all music and data."
For this FREE answer, Please rate me
SOURCE: how to unlock my ipod
