Position 856 1617000836 a broken hammer piston in the worst case but you have to order 1 617 000 A15 a maintence kit and special lubrication used 50 ml 1 615 437 512
INSPECT CAREFULLY THE 1 617 000 838 Hammer Pipe for rips if all parts are unmounted of the hammer pipe tap it with a metal object then it should not have any dull sound treat like a tuning fork for control for rips. thats important before repair consideration before.
The lubricant will be quite thick and that can also be the case only , (only have had its working hours on it) the revision of this hammers are easy to do it yourself clean solvent all metal parts that you re-use again to do the job you have a bench-vise and tools , for the striker pin in case there are no special tools neccesary like other hammers like a suggestion the Milwaukee 500S or other proffesional hammer because of the need of special seals and tools are neccesary , in between 1 and 2 hours are taken to service this Bosch hammers sometimes its neccesary to be aware of 1 ring to replace first of all because its easy to forget this ring on position 104 1610210095 o-ring that will very easy forgotten in practise with some grease replace it first of all spare parts.
Bosch Parts Service Online Illustrated Part List
SOURCE: I have a Bosch brute jackhammer, I need the tool
You can use an adjustable face spanner wrench to remove that cap. I don't remember the pin size but you can measure the holes and get the appropriate size. You can remove the whole plate with the armature by undoing the 4 cap screws. Prior to removing the motor plate you have to remove the handle plate from the axle that goes through the body. Undo the nut that holds the assembly on and slide it off. You can now remove the Armature plate. After removing the cap screws pull the assembly out about 1-2 inches. You will see the wires that go to the field attached to the brush holders. Remove the screw that holds these wires to the brush holders. You can then safely remove the whole assembly. This also makes it easier to remove that cap plug with the spanner wrench, because you can now put the whole assembly in a vise. I always heat around the cap with a torch before doing anything. Then I tap on the plug with a hammer a couple of times and voila it turns alot easier. Corrosion almost always builds up on this cap because of the different metals. (Steel and Aluminum respectfully)
Your hammer may have a broken connecting rod. To inspect this make sure you ping the cylider and body with marks so you line them up the same way. Then remove the 4 cap bolts that hold the cylinder to the body. Remove the cylinder and inspect the hammer cylinder and rod. If the connecting rod is not broken you will have to inspect the gears and pinions to make sure they are ok.
SOURCE: Bosch Hammer drill. When drilling, the
I would say that the motor shaft is probably bent and will need replaced.there are bosch service centers all over unfortunatly the price of parts especieally if it is a older unit can be almost what the unit costs.Sorry I'm not more help as I have several bosch tools in my shop and they are top quality tools. However I also have an old 65# electric breaker out there that is gathering dust because it has a cracked armature and the parts alone to fix it are in excess of $800.00. Best of luck to you and thanks.
