SOURCE: IBM Wheelwriter 15 Series II-Program the memory
The WW15 does not have a recallable memory, it has a reprint memory that will repeat what you have JUST typed, code reprt top left kry on the keyboard will activate if you want a full memory get a WW5 or 6.
Dicky O
SOURCE: IBM Wheelwriter 30 Series II
On the l. side of the keyboard there are keys labeled store, play & delete. Press & hold store then type an address 01 thru 99 release store and type whatever you want. Upon completion press store again. To play it back press play and the address, to clear delete and address.
DickyO
SOURCE: how to set memory
On the L. side of the keyboard there are 3 keys store, play and delete.
To store hold code and press store type in 01-99 for an address, rel keys, type info. when complete press store.
To play press play and the address 01-99 to print.
To delete press del. and address.
DickyO
SOURCE: Typewriter won't return carriage
If cleaning and oiling the shaft doesn't work, the carrier motor is probably bad. Is there any noise when you hit return?
SOURCE: IBM Wheelwriter 3500
First look inside the typewriter for forgien objects and debris, Then put some libhe oil (WD40 works well) on the shaft that the print head slides on.
DickyO
