I think I opened my iPad 2 too many times I changed my passcode and it says swipe to open but touch control does not work nothing is
Go to this link, the scroll down to the section titled, "How to Hard Reset iPad".
https://www.lifewire.com/how-to-restart-ipad-1999820
SOURCE: My Ipdad is disabled
You should log onto Itunes, and when you go on Itunes you connect it. After that you just have to restore your ipad and go through the setup again. The only problem is that all the things you have saved on the Ipad will be erased.
SOURCE: I turn off my ipad passcode an it still comes on
Go to settings > passcode > turn passcode off ! At each stage you will be asked to enter passcode for security! After this is complete when you go to settings > passcode, you should see "turn passcode off"
SOURCE: forgot pass code to open tablet
i dont know of any way to do this without a factory reset. first shut down you tablet. then start it up in recovery(hold power + volume down). and last use volume buttons to scroll down to factory reset
SOURCE: How can I reset my Galaxy tab 2 7 to its original settings?
Samsung Galaxy Tab 2 7.0 - How to perform a hard reset with the ...
https://www.androidpit.com/.../samsung-galaxy-tab-2-7-0-how-to-perfor...
Jun 18, 2014 - Samsung Galaxy Tab 2 7.0 - How to perform a hard reset with the ... From the Backup & restore section, ensure the appropriate account is ... In Menu mode, select Settings ? Privacy ? Factory data reset ? Reset Tablet? ...
Samsung Galaxy Tab 2 10.1 - How to perform a hard ...
Jun 18, 2014
How to Hard Reset the Galaxy Tab 3 - Android Forum ...
May 7, 2014
More results from www.androidpit.com
Galaxy Note 5: How to Perform Soft & Hard Reset
www.technipages.com/galaxy-note-5-how-to-reset
Aug 23, 2015 - If you want to sell or give away your Samsung Galaxy Note 5, or if you're ... The hard reset will wipe all files off of the internal memory, as well as ... your phone and just perform a factory reset as a way to make it their own. ... November 7, 2015 at 3:44 pm ... I have problem with my Samsung Galaxy tab 2 ...
How to Hard Reset/Factory Reset Samsung Galaxy Tab 2 7.0
? 6:01
https://www.youtube.com/watch?v=7sbgN0PxMzc
May 2, 2013 - Uploaded by HARD RESET KING
How to Hard Reset/Factory Reset Samsung Galaxy Tab 2 7.0Android 4.0 ... hi I got the same one as you and ...
