Http://support.lexmark.com/index?page=content&locale=en&productCode=&segment=SUPPORT&clearQuestion=Y&userlocale=EN_US&id=HO3026
That is a general printer error
Check for jams or blocks. you might have to delete the driver and clean the registry I use revo uninstall. then install the latest firmware
Sir Dana
SOURCE: I need to know what
There are 6 led lights on the printer panel and 2 buttons (Cancel -red button and Continue-green button). The lights can be OFF, ON, Blinking and Slow blinking. I'd be glad to provide you information about this, but I would like to verify if you are referring to a blinking light, slow blinking or solid light (ON).
Also you may download the user guide available from Lexmark's website. On the user guide you may go to page 21 Understanding the printer control panel light sequences.
For further assistance, please call Lexmark Technical Support
SOURCE: Just installed new printer Lexmark
This light sequence means that the printer has a service error, and printing has stopped. Please Press Continue button (green button) twice to see the secondary code. The secondary error code will help locate the problem. Please take note which light will be flashing for this will reveal what problems you have on the printer. For further assistance, please contact Lexmark Technical Support.
SOURCE: A impressora lexmark e260dn não
O cartucho de toner pode estar ficando com pouco toner: ? Remova o cartucho de toner eo cartucho de toner. ? Shake it dum lado ao outro para redistribuir o toner. ? Reinstale-o e verifique novamente para a condi??o. Para obter mais assist?ncia, entre em contato com o Suporte T?cnico da Lexmark
We would like to know more about the flashing lights you're referring to. The lights are represented by Error, Jam, Load Paper, Toner Low, Ready and Continue (green button).
For us to give the common light sequences, please provide us information which light is flashing on the printer.
For further assistance, please call Lexmark Technical Support.
We would like to know more about the second warning light you're referring to. Is it the second light from the left or from right side. The lights are represented by Error, Jam, Load Paper, Toner Low, Ready and Continue (green button).
For us to give the common light sequences, please provide us information if the light blinking, slow blinking or solid light.
