Washing Machines Logo
J
J Ottway Posted on Mar 24, 2017
The message flashing says 'door' what do I do?
Washer dryer no.wide 146
1helpful
I have a smeg washer drier wdi 146 with error code e13. Can you tell me what the problem might be. Thanks
i beleve your door interlock is fautly
or the wiring too it can overheat and cook
so youll need a new one from smeg uk
and check out the connector for any issues
see here for some details
although its a different model i would assume the company uses the same error code setup for all its models
and i would order direct from smeg
http://www.ukwhitegoods.co.uk/forumsphpbb3/washing-machine-forum/error-code-e13-smeg-wdi12c6-washer-dryer-t75513.html
2answers
Error message ERR1 on BWD1212 washer dryer?
Door not closing properly. Hinges may need adjusting. The door switches are very sensitive
Why is F16 code flashing up on my bosch avantixx washer dryer
The door is not locked properly.
Open and close the door again and press the "start reload" button (play and pause button). If necessary, open the washing machine door, remove some of the cothing items and then push the door closed again. You can also try switching the washing machine off and on again, setting the programme and then starting the programme.
I just had my washer-dryer repaired by CandyHoover. They replaced the tub and drum. I put it through the half hour cycle yesterday, then today I put a couple pairs of jeans in it on the 40C cotton
hi i had the same problem clean the door seal then use some disilled malt vinegar on a 90 wash then clean your filter out then use some bleach with your washing powder on 90 wash clean your filter then you should be all good then as that worked for me
Candy washer dryer 1400 spin cmd 146
try taking the soap dispenser draw out a give it a thorough clean inside and on the underneath of the drawer, then clean inside the machine where the drawer fits into. Sometimes a build up of detergent/softener can cause this.
I hope this helps
3helpful
My candy cmd 146 washer dryer
yes, 2 of them. front of the aly trunking on top of the drum. just press the little ceramic centers and it will work again, done mine 3 or 4 times now, bit annoying to be honest lol
14helpful
2answers
Candy smart cmd 146 ( washer and dryer)
Hi - You can download the manual from the link underlined in blue below:
Candy
Please take a moment to rate this solution & let us know if the information given was useful to you - Good Luck!
2answers
FRONT BELLOWS
I have a whirlpool duet washer i can't retrieve the model number because the door is locked but the dryer which is the match to the washer is model number GEW9200LW. My question is that when I hit the control button then start, a muttled beep will sound not allowing the door to open. I get an error message of DL then it flashes to F? Any help?
5helpful
Stop light flashing
i have a candy activa cm1 146. no matter what i do the stop light is always flashing. Ive emptied the machine, turned it off at the mains, checked the waste pipe and currently trying to empty the filter, whilst the light is flashing it will not work on any programs???
Error message
Switch machine off at the wall and leave off for 20 secs. Open the door. Switch back on again and close door firmly, giving the door handle an extra hard push. Should be o.k.
Top Washing Machines Experts
john h
