My search came up with "low pressure sensor error". Theoretically you could replace this sensor yourself but it will depend if you will be able to ensure you do not damage the port it screws into and it doesn't subsequently leak. Found a link with an image of the different types of sensor units in it -
have Kelvinator model KSV80HRA showing an E9 error code
SOURCE: MY KELVINATOR KL15TL WASHING MACHINE DOES NOT
I can think of three possible causes. The first is the timer not advancing to the wash cycle. Try manually advancing the timer and see if it will start. The second possibility is the drive motor or drive belt. Open the access panel to see if the belt is intact, then see if the motor starts when you manually advance the timer to wash. The third possibility is the lid switch. You can usually get to it by inserting a putty knife in the two from corners to pop the spring clips open, and the top flips back.
SOURCE: my AW-1170S toshiba washing machine
my AW-1170S toshiba washing machine was showing error code E7 -4...what does it mean?
SOURCE: Error code 5 on kelvinator KL55DFL
This code mean the control board or timer or clock has failed.
SOURCE: Our AW-1170S Toshiba washing machine ia showing error code E9-5 error message . How can I fix it.
Pam: This code relates to WATER PRESSURE , could be a (1) Krink hose, (2) plugged strainer where water enters the machine ( doing it's job) or (3) a sensor that malfunctioning (thinking you have NO water pressure. These sensor prevent the machine from operating dry, flooded etc, some times they OVER protects. So check the first 3 items above. you may have IN HOME service on it.
