Question about Minolta Office Equipment & Supplies
My konika minolta laser imager sigma is showing an error 607 how to solve it
  • Minolta Master
  • 6,862 Answers
What the model number???
Posted on Sep 02, 2018
6ya staff
SOURCE:
Nicolomd
Nicu Jenunchi
  • 84 Answers
SOURCE: I want cd for instale KONCA MINOLTA PAGEPRO 1300W (driver)
Try this driver (choose the operation system)
http://crm01.konicaminolta.eu/openmind/technic/kmpsdwl.nsf/psearch?OpenForm&ch=PRI&dist=BPE&ui=en&dg=sw&prod=PagePro%201300W&dsg=&os=&lang=&ml=0&rid=41256849005CE173&sub=Printer%20Driver&pcat=B%2FW%20Printer&pcc=1
don't forget to vote!!!
Posted on Jan 19, 2008
Bubbabear64
Tim Babcock
  • 2794 Answers
SOURCE: konika minolta
CDC##  Appears to be trouble related to security.
The only solution is to contact Konica Minolta to find out what needs to be done to resolve the problem.
That is only solution the service manual has provided.
Posted on Nov 07, 2008
mochicas
  • 26 Answers
SOURCE: Driver utility of Konika Minolta Bizhub 162
Use the bizhub 180 same family
driver
Posted on Feb 21, 2009
steve p
  • 44 Answers
SOURCE: error code c-2833
CAUSE: LD Power becomes saturated when performing Auto Gamma adjustment in a low humidity condition.
SOLUTION: Perform the following adjustment:
1. [Utility].
2. [Machine Admin. Setting].
3. [System Setting].
4. [Expert Adjustment].
5. [Process Adjustment].
6. [Toner Quantity / Exposure].
7. Select the proper Exposure Adjustment [Yellow, Magenta, Cyan, or Black] by using the Next/Previous button.
8. Select Standard then select [-2] under Exposure.
9. Press OK.
Notes:
a. If the problem persists, replace the problem color drum since the cause of the SC is the combination of drum characteristic and humidity.
b. The following codes = colors: C-2831 = Yellow; C-2832 = Magenta; C-2833 = Cyan; C-2834 = Black.
Posted on Dec 07, 2009
pineworks
Clive
  • 4345 Answers
SOURCE: konika minolta bizhub 350 Error c3451
Hi there.
Try this It could do the trick for you.
The error code c3451 refers to a copier warm up error; the machine had not reached the correct temp within a specific time.
I bet it happened when you first switched on one morning.
Easy to reset and fault usually goes away.
To Reset switch machine off using the switch inside the front door, not the one on the control panel.
Whilst holding the UTILITY key down on the control panel switch the machine back on keeping the UTILITY key held down. Eventually a Trouble reset key will be displayed in the LCD screen, touch this, OK will be displayed then power the machine off and then back on.
This will reset the error code, if the code reoccurs then there will be a problem with the fuser unit in the machine, and this will requir
e replacing.
Hope it did work for you.
Please come back and just gave a vote, it will gave me some satisfaction to know am helping some one so I will keep on helping.
All The Best: Pineworks
Posted on Apr 28, 2010
Konika Bizhub c452 error c2551
replace the cyan image unit BLUE
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/normanj_7893313f0751935f
Feb 01, 2014 | Konica Minolta bizhub C250 All-In-One...
Double image printing in konika minolta
replace the fuser
Dec 14, 2013 | Konica Minolta bizhub C351 All-In-One...
There is an error code c-2558 showing on my machine konica minolta bizhub c452 please do let me know the proper remedy for it ASAP
Abnormally high toner density detected Black TRC sensor-
1. Correct the TRC Connection on the underside of the imaging unit if faulty
2. Reinstall black image unit
3. Change image unit
4. Change PWB-M
5. Change PWB-MFP
you can try # 2 then run 20-30 sky shops (copies with lid up to make black copies) put a white piece of paper over lead edge section of copy glass so you are only making 1/2 black copies if you don't the copy may jam in the fuser due to excess toner. after running copies turn machine off for 10 secs to reset and power backon. if problem continues I would change the image unit.
Aug 21, 2011 | Konica Minolta bizhub C250 All-In-One...
I have problem with konika 1380 multifunction, error is service call 40.....pls give the soluton. Thanks Raj
Laser error
The laser output exceeds the upper limit value.
The laser output remains lower than the lower limit
value.
Apr 06, 2011 | Konica Minolta PagePro 1380 MF Laser...
VERTICAL LINES ON KONIKA 2400
If the line is white (no toner is added in that area) check the laser head glass which is located right below the drum. Remove the drum and you should see it below a narrow strip of glass. Just be sure to be clean, with no dirt, toner or pieces of paper on it.
Reset your Toners and Imaging units for Bizhub and CF series.
http://www.chipreset.eu
Oct 22, 2008 | Konica Minolta magicolor 2400 Laser...
Top Minolta Office Equipment & Supplies Experts
Adorjani Laszlo
Norman  J Weimar Jr
Norman J Weimar Jr
Ed
Ed
Are you a Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
