SOURCE: Unlock code
To accomplish the unlocking of your Samsung R210 Spex due to forgotten or unknown user lock code I used the following method. First, you will need a data cable. I bought this one from eBay...
Data cable
http://cgi.ebay.com/ws/eBayISAPI.dll?ViewItem&ssPageName=STRK:MEWNX:IT&item=260427509638
Create a folder on your desktop. I named mine Samsung R210.
When you plug your phone into the PC it may be recognized and work. If not you may need the USB drivers also.
Unplug the phone.
Open the Samsung R210 folder and create another folder. I called mine USB driver. Download this driver to the USB driver folder...
http://forums.mobiledia.com/cgi-bin/redirect.cgi?http://members.chello.nl/dondiegox/Samsung/Flashers/Z100_Downloader.zip
In the zip file there's a folder called Samsung_USB_install
Unzip it into the USB driver folder also and click on setup.
Reconnect the phone.
Check the control panel under USB and ports COM and LPT. My phone appeared on COM 10 under ports COM and LPT.
Next, create two more folders inside the Samsung R210 folder. I called them PST and Cricket DLL. Download Samsung PST lite and DLL installer files from the following two links into their respective folders.
Samsung PST lite...
http://www.mobile-files.com/forum/attachment.php?attachmentid=2274&d=1105395154
Cricket DLL file for the PST...
http://www.megaupload.com/?d=N3XTCO3W
Unzip them both into their same folders.
Run the install for PST.
Run the install for the Cricket DLL.
There should now be a shortcut on your desktop named Samsung PST lite. Double click it and you should see the PST Lite window.
Double click SCH-R210 on the right.
This should show you the unlock code in the next window.
If you don't see the info click the read general information button at the bottom. Write down the user lock code or be sure to remember it. Close the windows. Disconnect the phone. Enter the lock code into the phone and you should be free!
PS, I got my R210 Spex off eBay for $0.01 because it couldn't be unlocked! I have a feeling those prices will go up now that this info is on the web.
SOURCE: i buy Samsung Galaxy Tab sprint bad esn from
Hi there, if 1234 and 0000 are not work try code *2767*3855#
If fail, please visit below websites : www.muskurahat.us/mobile/samsung_tricks_and_tips.asp
www.ehow.com > Electronics > Cell Phones > Reset Phone
forum.gsmhosting.com/vbb/f200/all-samsung-hard-reset-codes-588846/
www.unlock-zone.com
jay--nbh887y654
SOURCE: i just bought Samsung Galaxy
do one thing Turn Off Your Tablet
-> Hold Volume Button and Power button for 3 to 5 Secs
-> You will see a screen with android and triangle with exclamation mark
-> you will also see 4 lines of writing in blue.
-> use volume buttons to navigate to 3rd option, use home to select it ( warning this will erase your system data if need please take backup) (memory card is not affected)
-> now navigate to 1st option saying " reboot to system" use home key to select it.
I hope this will fix things
SOURCE: samsung galaxy tab . written manual I would like
http://www.samsung.com/us/support/downloads/SCH-I800BKAVZW if this helps please vote
SOURCE: cant print from android (samsung galaxy tab)
Lexmark
just recently released the Lexmark
Mobile Printing Application for use with Android devices, however, the
application is supported only on most laser products and the very latest inkjets that
are coming out for 2011(the Lexmark Pro715 and the Pro915 are the only
models announced at this point.).
