Tablets & eReaders Logo
Vikesh Dhayaram Posted on Apr 02, 2017
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Reset Apple ID on ipad - iPad Apple Tablets & eReaders
String Picker
Level 2:
New Friend:
  • Expert 48 Answers
  • Posted on Oct 25, 2017
String Picker
Expert
Level 2:
New Friend:
Answers
48
Questions
0
Helped
5209
Points
145
Under "settings," go to "general" and look at the bottom where you'll find "Reset." This will reset your iPad to factory settings where you will be required to reset your Apple I.D. to your own personal settings.
5 Related Answers
Jim Thomson
  • 1099 Answers
  • Posted on Feb 06, 2012
SOURCE: how to creat Apple ID for Ipade 2 16 gb
Go to https://appleid.apple.com/cgi-bin/WebObjects/MyAppleId.woa/
Rick kearney
  • 13 Answers
  • Posted on Jan 08, 2015
SOURCE: how do i factory reset apple ipad i forgot my apple id and password
Resetting the ipad will not help... The I'd and password are stored at the apple store.
ineedabin50249
Joe Stanch
  • 755 Answers
  • Posted on Jan 10, 2015
SOURCE: i have an ipad that ask me for apple id that was used to erase this ipad.how do i get pass this
you do not , it is locked to icloud and the real owner is the only one that can open it , look on youtube you will see what I mean
zorahhudson
Zora Hudson
  • Posted on Jan 03, 2017
SOURCE: re set ipad mini
Generally speaking, you need the Apple ID to reset your iPad. iPad needs you to enter the Apple ID to switch off your account and the Find My iPhone service will be turn off. If you are using iTunes to reset your iPad, you need to enter the Apple ID when your iPad reboots.
But if you have no Apple ID or passcode, you will have to reset your iPad without Apple ID. To reset iPad without Apple ID, you need first put iPad into DFU mode and connect it to your iTunes. Your iTunes will help you to reset your iPad without entering Apple ID easily. Resetting your iPad with this method will result in wiping all the data in your iPad. The following steps will show you how to do that.
Step 1: Open iTunes on your computer and connect your iPad to the computer with a USB cable.
Step 2: After that, turn off you device. Press and hold the Home button for 3 seconds.
Step 3: Put your iPad into DFU mode: Press and hold the Power and Home button for 10 seconds. Then release the power button and keep holding the home button. When you see the Apple logo disappears, you have successfully put your iPad into DFU mode.
Step 4: When iTunes detects that your iPad is in recovery mode, you can restore it now.
Step 5: Click on Restore iPad. Then you will be notified after the reset and your iPad will take a restart.
After resetting your iPad with the guidance mentioned above, you'd better create a new Apple ID and password in time. After resetting iPad, you will get all the data swept from iPad, and you can restore the files from your iPad, iTunes backup or iCloud backup. However, you can't backup iPad to iTunes/iCloud without Apple ID before you reset your iPad. In this case, you need the third-party iOS data recovery software to help you recover lost data from iPad after factory reset without Apple ID.
http://www.leawo.org/tutorial/how-to-reset-iphone-without-apple-id.html
matthewjanne
Matthew Janney
  • 82 Answers
  • Posted on May 02, 2017
SOURCE: my ipad is saying apple id disabled,how do I get it un disabled?
How To Resolve The Apple ID Locked Or Disabled Issue?
Well, if someone unfortunately tries to hack into the user's Apple account by entering the password incorrectly infinite times, or even giving various wrong answers to your security questions, Apple will further easily recognize the attack and will entirely lock your Apple ID. As researched by Mac technical support team, it's a good sign because it signifies that an attacker can't anyway gain access to the user's Apple ID to avoid allowing them get into a user's iCloud email, iMessages as well as FaceTime. However, it may often happen that it's not a hacker who is trying to get access to your account, sometimes it's only we who is getting ourself locked out of the account because we have forgotten the password.
Solutions to resolve the "Apple ID Locked Or Disabled Issue.
Solution1: Unlock the Apple ID Whatever the reason for Apple's disabling the account is, there is every possibility to get back into it. One simply needs to follow all these below mentioned tricks to recover their account and create a new password.
  • Go to the iforgot.apple.com section
  • Enter the Apple ID which will usually be the email address associated with the user's Apple account.
  • A professional team of Mac tech support experts have suggested to enter the Code to prove that a particular user isn't a robot.
  • Click on the "Continue" button
Solution2: This phase is based on the security process
·If you are working with the set up two-factor authentication then it is quite possible for users to receive a code on a trusted device or as a text message on the phone. Users are required to enter the verification code before unlocking their account and changing the password.
·If anyone is working with older two-step verification process, then a recovery key is needed that was sent to them while setting up two-step verification process in addition to a code sent to a trusted device.
·Well, if a user haven't set up either of the above methods for security purposes then one needs to unlock the account by using their password, or simply has to answer few provided security questions at the some point.
Fix your Mac issues with expert team working at Mac customer support Toll-Free 1-800-213-8289 department and get all your headache resolved at a go.
How do I unlock my ipad activation lock without i-tunes. I forgot my password and apple I'd.
If you bought a second-hand iPhone/iPad stuck on the activation lock screen and don't know the previously used Apple ID and password, iMyFone iBypasser can help you activate iPhone/iPad without Apple ID. This excellent tool came out in 2020 and has helped many users who reset their own iPads without logging out the previously used Apple ID.
My sister forgot her Apple ID on her iPad and she's 55 and can't remember her password what to do?
Under this circumstance you may have to reset the iPad if you forget both Apple ID and its password.
To reset iPad without Apple ID, you need first put iPad into DFU mode and connect it to your iTunes. Your iTunes will help you to reset your iPad without entering Apple ID easily. Resetting your iPad with this method will result in wiping all the data in your tablet. The following steps will show you how to do that.
After resetting your iPad with the guidance mentioned above, you'd better create a new Apple ID and password in time. After resetting iPad, you will get all the data swept from iPad, and you can restore the files from your iPad, iTunes backup or iCloud backup. However, you can't backup iPad to iTunes/iCloud without Apple ID before you reset your iPad . In this case, you need the third-party iOS data recovery software to help you recover lost data from iPad after factory reset without Apple ID.
Re set ipad mini
How can I reset password for my Apple ID to get into ITunes?
Recover or Reset Forgotten Apple ID or Password on iPhone & iPad
This is all done on an iOS device and is often the simplest way to log back into an Apple account:
  1. Open the Settings app and scroll down and tap on "iCloud"
  2. Tap on the email address at the very top of the iCloud settings screen
  3. Tap on the blue text underneath the password entry that says "Forgot Apple ID or Password?" where you'll have two choices:
    • If you know your Apple ID and don't remember the password, type in your email address and click "Next" to start the reset process
    • If you don't know your Apple ID, tap on "Forgot your Apple ID?" and fill out your full name and email address to recover the Apple ID login (yes, you can then do the password reset after you have the Apple ID)
  4. Answer the security questions pertaining to that Apple ID, and follow the onscreen directions to complete the process
At this point you should be good to go, you can reset the password for the account and then login as usual.
How do I reset my Apple ID and password on my apple iPad Air without boot disc or iCloud password
Follow these steps to reset your forgotten Apple ID password: https://support.apple.com/zh-cn/HT5787
How can I remove a previous owners Apple ID from an iPad?
You need to either connect the iPad to iTunes and select "set up as new iPad" or you could also reset your iPad by opening settings/general/reset and choose "reset all content and setings". Both ways will delete all apps and you have to purchase or reinstall them.
How to reset my apple ID on my I pad
This needs to be reset by the Apple ID that first setup the Ipad. If you don't have that - you can take the Ipad to an Apple Authorized Service Center - along WITH a receipt or proof that you own the Ipad - and they can reset the device for you.
How to hard reset ipad air to recognise another apple id
Go to Settings... / General
At the bottom of the list is Reset
You can do a full reset from there.
Top Apple Tablets & eReaders Experts
nexrad_chris
NOEL
NOEL
John
John
Are you an Apple Tablet and eReader Expert? Answer questions, earn points and help others
