When i push down it will not record or see reds
SOURCE: blinking red timer light
The blinking red timer means that the date isn't set on your camera. Go to the set up screen and set the date. I'm not sure why you wouldn't be able to take pictures, though...
SOURCE: red blinking clock on nikon
The clock isn't set OR it's been a while since you used the cmaer OR you let it sit on low charged/dead battery for too long. Either way, update the date and time and it should go away.
SOURCE: red hand blinks on screen upper right side. how do
The red hand icon flashing shows that the camera is using a slow shutter speed, and
is a warning to be careful to hold the camera steady.
You could put the flash in auto mode and it will fire when the light is low.
SOURCE: Red clock flashes
just correct the date and time in your camera and it will stop flashing,thanks. from [email protected]
SOURCE: Hi I have a Nikon
There is a capacitor dump that you can try.
Remove the batteries, wait 5-10 minutes.
With the batteries out, press and hold the power button for 10 seconds or so.
Put the batteries back in and your camera will start over (re-boot). You will know if it worked if you have to reset the date. But if that lens is really stuck you may be out of luck. The cost to repair it will exceed the cost of a new camera.
