SOURCE: Can't play EA games online.
There's a possibility that your location may be the issue. On the other hand, there's alot of issues out there very similar, if not identical to yours. but SO many give SO much different advice on how they think it should be solved, there's no way to know which ones click & which ones missed.
A few folks said "power cycling" their router helped them. Unplug it... Wait 30 seconds... Then give it a go. Some folks with both PS3 AND 360 said it's happening on BOTH with EA! So that says alot about EA's servers.
Try these links for further info
http://support.ea.com/cgi-bin/ea.cfg/php/enduser/std_adp.php?p_faqid=19293
http://en.kioskea.net/forum/affich-11615-trouble-with-online-gaming-when-using-router
http://boardsus.playstation.com/playstation/board/message?board.id=fightnight&thread.id=2593
http://www.gamespot.com/pages/forums/show_msgs.php?topic_id=26470441
http://www.neoseeker.com/forums/30444/t1192332-eas-online-games-using-wireless-router/
Hopefully, these links will point you in the right direction. Good luck, bro! Please, don't forget to rate!
SOURCE: Webcam wont work with windows live messenger 9.0
un-install the windows live messager 9.0 and reinstall messager 8.5.
http://www.softpedia.com/progDownload/MSN-Messenger-8-Download-68149.html
SOURCE: Xbox live connection interrupted every game
as you may already know its probably not your router... check and make sure you have all the XBOX live updates on your 360... the link below should get you started.
http://www.xbox.com/en-US/games/backwardscompatibility.htm
SOURCE: xbox 360 can't connect to "xbox live party" for me or my friend
make sure u both have gold and make sure ur network doesnt have strict security
Set up your Xbox Live connection by connecting your Xbox 360 to high-speed Internet. There are two options: connecting it to your network via Ethernet cable or connecting to your network via a wireless adapter. The simplest and fastest connection is connecting via Ethernet cable directly to your modem or router. If you must connect wirelessly, use the Xbox 360 wireless adapter, sold separately. See the Resources section below for connection tips.
Test your Xbox Live connection after connecting your Xbox 360 to your high-speed Internet. Navigate to the dashboard, select "My Xbox," choose "System Settings" then "Network Settings." Run the diagnostic test to confirm your connection works. Your Xbox 360 will offer troubleshooting tips if the test fails.
Create an Xbox Live gold account. Log out of all profiles then press the "Guide" button and choose "Join Xbox Live." Follow the prompts, entering your billing and personal information. You will also choose your gamertag during this process, which will serve as your online name and identity. Lastly, you will customize your profile. Your Xbox 360 will then create the account.
Insert your Xbox Live multiplayer game and open the game's Xbox Live multiplayer menu. Different games have different options but certain features remain the same across all multiplayer games. There is the TrueSkill ranked matchmaking system, which pits you against players of similar skill levels. There are also unranked player matches, where you can practice and hone your skills in a non-competitive atmosphere. Lastly, there is the quickmatch matchmaking system, which automatically searches for games for you, whether they are unranked or ranked.
Add and play with friends. Xbox Live allows users to add up to 100 friends. Add a friend by pressing the "Guide" button, navigating to the "Friends" tab, then selecting "Add Friend." Type in your friend's gamertag then press the "Start" button and choose "Send Friend Request." Your friend will need to confirm the request to complete the process. You can play multiplayer games with friends by opening your friends list and inviting them to a game lobby.
Communicate with friends and opponents using an Xbox 360 headset. The wired Xbox 360 plugs into your controller. Once it's plugged in, you can speak into microphone and listen to others from the ear piece.
