Find other canon driver by click the link
Canon MX922 Driver & Software Download Support for OS Windows, Mac, and Linux - The Canon MX922 also provides a new high-capacity 250-sheet primary paper cassette, so you're able to target on your own do the job and not functioning outside of the paper. This could undoubtedly deliver office efficiency to all-new ranges.
Canon MX922 Driver
Canon MX922 Driver Download Canon Printer Drivers
you also can download canon mx922 driver here, it give good pleasure to install it..
Since you do not have a dial tone, please ensure that the line coming from your telephone source is plugged into the LINE jack on the unit. If you are connecting a telephone or answering machine to the unit as well, you will want to plug them into to the EXT jack on the unit. Please ensure that the unit is turned off when connecting the telephone line and telephone/answering machine to the unit. More information on connecting the lines and devices to your computer can be found
Once these items have been verified, if you still are unable to hear a dial tone when you press the HOOK button on the unit or are unable to send a fax, please call or email us using one of the methods on the page for further assistance.
Canon PIXMA MX922
SOURCE: MP830 Canon Faxing problem
Display the fax menu and then select Print Report\List and print the Users Data List. Check the setting of the ECM TX setting. If this is ON turn it OFF. This is the Error Correction Mode setting, probability is the fax you are sending to is not ECM compatible. The MP830 is suppose to automatically send in standard mode if receiving machine is not ECM compatible however I am not sure how well this works. Turn the ECM setting off by displaying the Fax Menu and then select Maintenance\Settings, Device Settings, Fax Settings, TX settings, ECM TX.
SOURCE: Canon MP530 - Fax - ERROR TX Report - NG
Hi flyme.. I have the same problem but on an MF5770 all in one MFP. If anyone can solve this then wow.. I've been trying to find a solution for over 18 months now...
SOURCE: Getting Error TX Report: Result 'NG' - what does this mean???
It means No Good or Not Good, fax was never received for a number of reasons.
SOURCE: trying to fax with pixma mx7600. Plugged phone
You probably want to plug the phone line (the line from the wall) into the port marked "L" for line on the back of the Fax machine. The jack with the picture of the telephone handset is for your optional voice phone to share the same line with the fax machine.
