Thermostat fault or control dial /buttons faulty
Under normal use does the main oven fan stop whaen the thermostats reaches temp.
if normal baking or roasting the fan kicks in and out to keep evem temp
but fan is never supposed to let the oven go cold while baking
Ok thanks. Sounds like the thermostat then
I have removed the stat ans seems okwith multimeter. It seems the fan cuts out first as the oven is building temperature, not aftert the thermostat cuts in and tuns off element
Removed the stat to test it, it only has 2 conmections. How is the fan cutting out first if not linked to thermostat?
get a cheap oven shelf internal thermostat and take its readings when fan shuts off and if it re starts
I did last night, was cutting out at 190 to 200. Only came back on one switched off and cooled right down to 50
there you have it needs a oven technician to sort it
fan itself failing . the dial or control circuit board short .. faulty wiring for the thermostat
I'd say its the oven thermal cutout. Its set to open cct the supply to fan and element if the casing reaches 170. In my case the fan failed first which must have affected the thermal cutout. I've just ordered 2 as I goosed my top oven one trying to swap them round, guess they get brittle as they age.
Order code KSD301A-180AR-BT from sinolec
