Unlock Code For ZTE 820
Brand Name: You need to give your phone brand name like ZTE, Samsung, Apple
Model No: You need to provide your model no
Here is the easiest way to check your phone's model name and number
Go to the Settings? About phone OR About device?the device name and model number should be listed there
Network: You need to give your network on which your phone is locked
How to find locked network: - To know your locked network follow the steps below:
-Insert SIM card from a source different than your original Service Provider (i.e. if you are using AT&T then insert Sprint or T-Mobile Sim )
- Phone will show the following message "Enter PIN" or "Enter Pass code or unlock code or NCK code or enter PUK code" then
your phone is locked for AT&T network
Buying Country: You need to provide the country name by which you purchased the phone
IMEI No: This is the important thing to unlock any phone
How to find IMEI No
-Dial *#06# from your mobile or
- Go to the Settings? About phone OR About device?the device name and model number and IMEI no should be listed there
- On some cell phone you can see this below the phone battery
Note: - To get the unlock code for any phone IMEI should be clean (Not blacklisted) and out of contract otherwise no online tool avail to unlock your phone
So here is some online tool avail to check the IMEI Status
http://www.imeipro.info/check_lg.html
For Huawei
http://consumer.huawei.com/es/support/warranty-query/
For T-Mobile
https://www.t-mobile.com/verifyIMEI.aspx
Once you are ready with the above details you need to order for
phone unlock code to any service provider who give Safely, Legally, Quickly, Forever unlocked ! online service like unlock ninja
They deliver the unlock code within least minimum time frame (Code delivery depended on your country and network)
Once you get the unlock code you need to follow the steps below to use this
How to Unlock a ZTE Phone
1.Insert SIM card from a source different than your original Service Provider
(i.e. if you have a Rogers phone, use a non-Rogers SIM card),
2.Phone will ask you to enter Sim unlock pin (NCK code or PUK Code )
3.Enter unlock code
4.Phone will be unlocked
