Watches Logo
A
Anonymous Posted on Apr 08, 2017
How to change date on shhors digital watch - Watches
How do I changed the date on my wrist watch, TGHK AW 91-731, without changing anything else.
You can experiment.most digital displays need you to hold the top button in for 3 to 5 seconds to get it to start flashing then use the other button to scroll through each part of the menu and adjust up or down each number and Date.finally when you are happy with the setting just press top button again for 3to5 seconds.
Feb 01, 2016 • Watches
1helpful
How do I use the buttons in this QHY watch?
Hopefully, this will help...
Lego Watches Manual Instruction:
There are 4 buttons on this lego watch case, Light button, Mode button, Stop button and Reset button, now I will show how to set the time easily!
1, Light Button: Press this button, the watch LCD light will display for 3-5 seconds;
2, How to use the stopwatches chronograph function?
Answer: When the lego watches in normal working condition, Press "Stop button" for 1 time, then the watch goes into the chronograph mode, then you can use "Stop button" and "Reset button" to operate this function.
3, How to set the alarm time?
Answer: When the lego watches in normal working condition, Press "Stop button" for 2 times, then the watch goes into the alarm mode, then you can use "Stop button" and "Reset button" to set the alarm time, also you can turn off or turn on the alarm function and chime on every hour function by the same operate.
4, How to set the right watch time, hour, minute, second, week, date, month, year?
Answer: When the lego watches in normal working condition, Press "Stop button" for 3 times, then the watch goes into the time setting mode, then you can use "Stop button" and "Reset button" to set the second, minute, hour, week, date, month and year.
This is all. So now please have a try to set your lego watches time!
Dec 06, 2014 • Watches
Need manual / instructions for shhors watch
Mine is like those but brand shhors. I change time by holding reset. What concerned me is what are the digits displayed: first comes time, then comes the month and the day in small digits, and then comes 20 and two digits for year which is soon 23. After youre done reset finishes all.
Dec 13, 2013 • Watches
1helpful
Can't change minute , day and date on shhors Lego watch
Whilst on the normal time screen; press MODE 3 times passing through STOPWATCH, and ALARM. Now back on the time screen; you should be able to press RESET to move through all the fields on the screen and ST/STP to change number/value. Pressing MODE once more goes back to normal time screen use. Hope this helps. Nich.
Aug 10, 2013 • Watches
How to set time on a 1440 timex watch
Hi tsgoode99,
To set the digital time and date on your Timex, please follow the steps below.
Timex Digital Watch
1. Press and hold the "Set" button for 2 seconds. The "Set" button is on the lower right side.
2. Press the "Date Advance" button on the upper right side. This will reset the seconds.
3. Press the "Change Mode" button on the lower left to set the hour. The hour will flash. Press the "Date Advance" button until the correct hour is displayed.
4. Press the "Change Mode" button again to set the correct 10s unit (first digit 1 or 0) for the minutes. Press the "Date Advance" button until the correct first digit of the minutes is displayed. Repeat this step to set the second digit of the minutes.
5. Repeat Steps 1 through 4 of this section to set the year, month, date and day and whether to use 12- or 24-hour time for your watch.
6. When finished, press the "Set" button (on the lower right) to return to the current time view and lock in your settings.
Hope it helps.
Thank you for using FixYa.
1440 date change
Hi jhnmeserole,
Timex Digital Watch
Hope it helps.
How do I change the time and date on my Timex 1440 sports watch? Cindy
Hi Cindy,
Hope it helps.
I can change everything but the date. How can I change just the date on my watch. The model I have has 4 buttons (Mode, St/Stop, Set, and Light). Can someone tell me how to change nothing but the date?...
Hi 1234910,
Hope it helps.
8helpful
2answers
Setting time on Seiko watch 7N43
Mike 1935 if your watch has hands only & no digital display the crown where you set the watch pulls out half a click to set the date and should pull out a little further to set the time try that.
bjbc I am assuming your seiko watch is a digital watch. Try holding in the top rt button if its the watch I think it is it should change to 12yr time.
Mar 09, 2008 • Watches
Top Watches Experts
john h
ADMIN Andrew
ADMIN Andrew
Ngoro
Are you a Watch Expert? Answer questions, earn points and help others
