SOURCE: Unable To Keep Pilot Light Lit!
I have a Williams top vent gravity wall furnace (model 5009622) and I had the same problem. I had to take the cover off the furnace -- screw on top and two at the bottom (open the access door and there is one screw on each side) to get to the reset button for the vent safety shutoff system. On my furnace it's on the left side toward the top of the unit. I pressed the little red reset button and it's been working ever since. If your furnace is properly installed and doesn't have bird's nest in the chimney, it should work fine. Good luck!
SOURCE: HP dv6835tx Notebook with Visa Ultimate 64-bit will not shut down
From what you've described, it sounds like you are clicking the Standby button, instead of the actual shutdown option. On the Start button, you will see (from left to right); Left: Start Search Middle: Standby Middle: Lock Right: Arrow Clicking the arrow will show you the Shutdown menu option; http://blogs.chron.com/techblog/archives/shutdown.jpg
SOURCE: problem with printer all buttons flashing
All lights flashing is an error indication. to learn the problem you'll need a service manaual. The procedure is to hit the Continue button twice - see which lights flash (secondary code) and consult the manual. Then repeat that step and look up the final code (tertiary code) in the manual. This should be the problem.
SOURCE: Dell Dimension 2300 - Boot Up Issue - Replace Motherboard?
I have issues after shipping with wires. Have had to pull and reset wires with the computer unplugged and 80 % of the time that has fixed the problem.
Testimonial: "The suggestion was helpful - together with another suggestion, it helped advance the ball. Moving on to another issue now. Thanks."
SOURCE: Williams 3003622 Wall Mounted 30,000 BTU The pilot
I'm having the same exact problem... At first we thought was the vent... but the way the flames goes out... it seems that there is "not enough oxygen" more than "blown out by the wind"... right after both main & pilot goes out, I can't even light any external flame inside the chamber... and it doesn't feel like the outside cold air coming in... it just feel like there is some sort of gas in the chamber that's so strong, it prevents flame... and the only thing I can think of is that it doesn't have enough oxygen, but too much natural gas, and flame can't sustain.
Please visit the Lexmark website to download and install the Lexmark X4650 Printer Driver on your computer. Select your operating system > click on "FILTER" > click on the driver under Recommended Downloads > download and execute the file. Simply follow the instructions on your computer screen to complete the installation.
