hmm im not sure if there's an issue with the base for your wireless phones but it maybe that the phones arent able to determine if the base is active (EG the right base for the phones) some may need to be paired up to the base or the base maybe malfunctioning due to the lightning storm (Phone lines are prone to being struck at times which could send a surge to some types of phone bases and ruin them)
tried to reset the tv first, if struck by lightning the tuner will be damaged or the main board but since the tv is still working so i think not the lightning was the main cause.
Yes. Although the tires are suppose to insulate, there is enough humidity to allow the air to carry a charge. The ECM for example, can be interfered with by Radio frequencies. A lightning strike produces all kinds of freqencies beyond visible light.
You should document the tree strike and park your vehicles back into their spots if you do not already have photos of the tree damage showing the vehicles in the foreground or background.
This is comprehensive coverage with hidden damage discovered within a recent timeframe of the original event.
power supply board is dead, u know basic electronics' and soldering? Most of the times, the power supply board just have dead leakages gases capacitors.These capacitors always bulges up on it top,or puff up on it top.Replaced these gases leakages capacitors will get your TV power stable,and work again.Or tries websites like Shopjimmy.com,Ebay.com to buy a whole refurbish power supply board for the replacement.
I am sorry to say but it sounds like you had a major surge go through your tv. Go to this area: TV Repair man in your area Find a repair place near you and have them check it out.
hi thanks for the question i would guess the motor but man thats a hard one if the dryer was hit by lightning it could have caused a fef problems myself i would call my insurance company tell them you were hit before you call the insurance check all appliances in your house you may find other problems thanks the appliance doc
It may be too late for this advice, but if you live in a lightning prone area, you should consider having a 'whole house surge protector' installed. The cost should be well under $300 (a lot less if you install it) and with the included insurance (most often for $25,000) it is a good investment.
If your house was struck, I'm surprised you don't have a list of things that no longer work.
No, I don't think it is worth the cost of a repair, if you can even find someone to do it for you.
Most of us are retired-
lightning is in KVolt range, the exterior unit is most likely damaged at the low voltage cables to the thermostat, melted out, should get a sparky in to trace the lowV lines, and check out the unit, lightning is not forgiving
