SOURCE: How do i change my language from arabic to english
This will work for all 2630's from whatever language it is currently set at to your desired language. Press the center square button to get the menu. Scroll down until you see the small wrench - menu #4. Press the square (Select) button again. Scroll down to #9 - the icon will look like a small phone with a wrench - press select. Press select again - menu #1. Press select again - menu #1. You should be able to see English as an option. Scroll down and select again and you should be good to go. The Nokia menu sequence is: Menu, 4, 9, 1, 1. Unfortunately, this phone does not do jumps - so you must scroll down manually.
SOURCE: i mate 6150 how to change the language arabic to English
hello
today i am going to show you how to change language arbic to english. First you go on
control panel. And then you see there regional languge you can see there lot of languge you.
Now wich language do you want you then you select that's it .
SOURCE: how to change language on nokia e52 from arabic to english
Hi there
I have found the userguide for the device on :http://nds1.nokia.com/phones/files/guides/Nokia_E52-1_UG_en.pdf
There on page 161 , it stats :
Language settingsSelect Menu > Ctrl. panel > Settings and General > Personalisation > Language
due to be at arabic language may nedd to check the icons on userguide.
I hope this information can help you.Best regards
SOURCE: i want to change language
change the language in nokia E66
1st Go to Tools ( your cell 5th option )
2nd Go to setting ( your cell 5th option )
3rd Go To general ( 1st option)
4th go to renationalisation (1at option)
5th go to language (5th option)
6th go to phone language (1st option)
than open your other language option
100% tested by me
