No spin, or lite spin try these: bare in mind that many times there is no spin it can be due to a clogged water pump so check it for debris and or broken propeller.
Other items to check Using a multi meter check for continuity the door switch, which when bad may not allow agitation or spin. Bare in mind the lid switch assembly can fail either mechanically or electrically.
Check the clutch, motor coupler, brake assembly, transmission, and mode shifter or actuator. one way to check for slipping is to get under the machine after a spin cycle ( this is if u get a lil spin but not much leaving clothes still wet) mix in a spray bottle a lil water and some dish detergent, then spray it on the clutch assembly ( the metal round pc. Connected to the tranny) if it sizzles and steams up then u know its bad and slipping. Another way to check clutch if u get no spin at all? Is to take it out and use ur hand to try and turn the inner spring assembly pushing it around the inside? If its very easy, it BAD should be hard to push by hand.
Or try the hand test:
If no hammering sound has ever been heard out of this machine, one of the unofficial tests we professional appliantologists will do in the field is called the Hand Test. WARNING:This test is not sanctioned by Whirlpool Corporation; it involves bypassing safety equipment and then putting your hand on and near rotating machinery which could result in injury, dismemberment, disfigurement, disembowelment, mangling, hideous screaming, and a ****** *****. Proceed at your own risk! Have a nice day.
- put the timer on a spin cycle and open the lid- grab the inner basket with maybe 30% to 40% of your hand strength with your left hand
- turn on the machine and bypass the lid switch by depressing the lid switch with a key until the machine begins to spin
- if the clutch is engaging properly, the basket should immediately begin to spin and slip through your hand
- if it takes very little force to stop the tub from spinning, the clutch needs to be replaced.
Next check the motor coupler which engages the tub and tranny to the motor. ( if its bad u usually get no wash or spin or very little of either)
Next if belt driven check for a loose, worn or broken belt. And on some models there is no clutch but rather what is called a splutch. And a MODE shifter. These can go bad and effect the spin cycle.
On some front load models u may need to check the STATOR assembly.
The stator is essentially one half of a motor, it interacts with the tub by creating a strong electro-magnet. If the stator burns out the washer won't spin or agitate. Check the stator for continuity. This part is often misdiagnosed.
Sometimes a no spin machine can be due to a plugged waterpump hose or obstructed water pump propeller. Check these by eye and hand. And in some models check with a meter for continuity and voltage.
LID SWITCH TEST- next step is toremove the cabinetand jumper the lid switch harness (tan to gray). Put the unit in spin and watch the shiny metal clutch disc that is on top of the transmission where the shaft comes out. If the machine starts and runs in spin, check to see if the disc is spinning. If it is, then the problem isnot in the gearcase- look for trouble in theclutch,basket driveor the tub drive block
If, on the other hand, the disc is NOT spinning, check for a problem withthe motor drive coupleror one of its retainers. This washer doesn't have a belt. Instead, the motor is directly coupled to the gearcase by a drive coupler; that's why it's called a direct drive washer.
Read more:Diagnosing and Repairing Spin and Agitate Problems in a Whirlpool / Kenmore Direct Drive Washer
http://fixitnow.com/wp/2010/07/07/diagnosing-and-repairing-spin-and-agitate-problems-in-a-whirlpool-kenmore-direct-drive-washer/#ixzz3XW7eZwiN
By the way my advice is free cuz God is good!
Diagnosing and Repairing Spin and Agitate Problems in Whirlpool Kenmore...
SOURCE: DST Short Status Test (Error detected)
DST stands for Drive Self Test, it means your drive is failing.
I would get a new hard drive and USB enclosure, install new drive in laptop and install windows, then take the old drive and install it in the USB enclosure so you can connect to your laptop when windows is running and restore your files, assuming the drive is not completely dead.
thanks for rating
SOURCE: Canon IR3170CI got a error E0014-002
k these are notorius for having bad upper rollers if they sit for a long time if you turn the green knob on the fuser and feel hesitation or its hard to move then easy.. or if it sounds like a washing machine at warm up you need a new fuser even if youswapped it the one you put in if not new may be bad
SOURCE: Maxent 26" lcd tv, shorted circuit board
the best and easiest way to track down a short is with a digital multimeter just check for continuity throughout the circuits.If you you cannot get your hands on a multimeter use a compass.It will detect and move left to right when there is a complete circuit and as soon as you hit the short the needle will be dead still. Fix the short and test.It would probably be alot cheaper than trying to track down a part with no certainty of it.Hope this helps
SOURCE: Hello-My Beko washing machine (WMA 1512 W)does not
recheck the brushes & pump/filter/outlet hose (make sure all cleaned out and impeller free to turn) your problem lies in there somewhere.
Testimonial: "Hello -The brushes have about 10mm left but will re-check ,the pump works well, I suspect the speed module board Regards Andyrooshous"
SOURCE: Frigidaire Front Load Washer won't Spin
i fixed mine about 5 times and its always some thing diffrent.
try buyng the inexpencive parts first and leave for last the electronic control panel.
it could be that your washing a smaller amount than the recomended.
Take it to a profesional. dont do like me a DIY guy. Some times i need to take pictures when taking the monster appart and then because they are somany screws missing duct tape, rope or hangerwire becomes usefull.
All mechanics are wise guys you and me are thevictims.
