SOURCE: Nokia6210 navigator battery gets warm
Good day sir/maam, your battery is bad, replace it. If still gets hot, you may need to bring your phone for service. the charging circuit maybe faulty.
SOURCE: my samsung pixon keeps freezing. I can turn it on
This is courtesy of Helifix from Handcellphone.com...
Hello Guys. I have the same problem and I found out the solution. The
problem is a faulty contact from the touchscreen leading to the phone
board. To be short: on the right side of the phone were the volume
buttons are, under the touchscreen is the screen's contact. Try
"detaching the screens face a little from the phone body exactly at the
volume down button(using ur fingernail or something) and see if the
touchscreen is responding in anyway. My phone has a bad contact there,
and in normal mode all is frozen. Now if I try to pull towards me, the
touchscreen frame from the rest of the chassis, only a mm SURPRISE!! My
touchscreen is working. IF this is your case too...I suggest get a
screw-driver and open the chassis, and trying to make the connection
permanent, somehow. I haven't done this yet, but will do it today. If
anyone is interested I could post the results:) PS: you can send it
back to warranty of a repair phone shop, only to force you to buy a new
touchscreen and pay for the repairs, on a 99% working phone, with a
faulty contact. The choice is yours:)
SOURCE: On my Samsung Galaxy Tablet i am unable to send or
place your sim on a another mobile and check still you didnt receive any messages. If still ther is no messages then contact your service provider and ask them why they block your incoming and outgoing message facility. If you receive messages on that sim then you can reset your phones software
SOURCE: galaxy ace battery drains fast
hy i too have that problem it sloved for me .. i will say the steps just do these steps properly ??
1... just root your phone and install root explorer.apk
2.Open root explorer app
3.then turn on r/o in the top it will in r/w .. change to r/o
4.then go DATA>>SYSTEM>>you will find batterystats.bin
5.Just delete it and charge your phone to 100%%
6.your problem will be no solved :)
7.
dont reboot or let to reboot your phone ..if i does then the
batterystats.bin will automatically created .. and Battery starts to
drain ..
8..then need to repeat the STEPS 3 to 5 ... :)
ENJOY
I Hope that i will usefull friends
SOURCE: my Samsung Galaxy Note 10.1 battery not charging can you please tell me why
mine still doesnt charge when it's turned off. it just vibrates sporatically. i had to get a totally seperate charger for my battery. it's stupid. so now i have to switch it out all the time
