Toshiba Satellite A15-S127 Notebook Logo
Anonymous Posted on Jul 24, 2009
AC LED blinks 5 times, then 2, then 1 and keeps repeating this pattern. This happens when I press the power button. Then I need to pull the power cable and the battery to clear the blinking LED.
Anonymous
Level 3:
  • Master 724 Answers
  • Posted on Jul 25, 2009
Anonymous
Master
Level 3:
Answers
724
Questions
0
Helped
187079
Points
1948
Sounds to me that the battery is bad and the LED is telling you something of this nature
Duse this happen without the batter installed?
Basically i plugged in the ac adapter to it, pressed the power button and the power light comes on for 2-3 seconds then the power light shuts off. lcd screen never turned on or show anything, fan never...
>>> Please leave feedback so I can continue helping You & Others
The middle blue led is the charging indicator, sounds like you have (at least) a bad battery, remove it, plug in AC and try again, if no good, remove the HD and repeat, if no good, remove/replace the ram and repeat, if still no good, your mainboard is cooked.
Thanks,
Adam.
4helpful
Alarm lights keep blinking after I changed my printer ink.
E5 means cartridges error - to fix press the "stop\reset" button for 5-7 seconds and then release it.
You can also try this:
1) With the printer power turned off but connected to a power source, while pressing the Resume/Cancel button, press and hold the Power button.
(DO NOT release the buttons. The Power LED lights in green to indicate that a function is selectable.)
2) While holding the Power button, release the Resume/Cancel button. (DO NOT release the Power button.)
3) While holding the Power button, press the Resume/Cancel button 2 times, and then release both the Power and
Resume/Cancel buttons. (Each time the Resume/Cancel button is pressed, the Alarm and Power LEDs light
alternately, Alarm in orange and Power in green, starting with Alarm LED.)
4) When the Power LED lights in green, press the Resume/Cancel button the specified number of time(s)according to the function listed in the table below. (Each time the Resume/Cancel button is pressed, the Alarm and
Power LEDs light alternately, Alarm in orange and Power in green, starting with Alarm LED.)
4 times----Green (Power)------Waste ink counter resetting
Need code for programing
Manual is available at One For All here
http://www.oneforall.com/uploads/support/6c8b036cd3ba3806d00e5a1c57409ef0.pdf
To set up remote
1. Turn on TV.
2. On remote press TV key once.
3. Press and hold Set button until LED blinks twice
4. Enter first 4 digit code for your TV manufacturer from the manual above (P.18). LED blinks twice if code has been entered correctly, if not go to 2.
5. Press Power and the TV should switch off, if the TV doesn't switch off go to step 2 and repeat with next code for your brand until TV does turn off.
Searching for code
1. Perform steps 1 to 3 as above.
2. Enter the code 991. LED will blink twice.
3. Press Power button.
4. If TV turns off
Press Set - LED will blink twice.
If TV doesn't turn off
Press TV button and go to repeat step 3 and 4, until TV does turn off.
Check a code.
If you've used the search function you might want to know what the code is to do this...
1. Perform steps 1 to 3 from set up remote at the top.
2. Enter code 990, LED will blink twice.
3. For the first code press 1. Wait 3 seconds and count the times the LED blinks, that is your first digit, if the LED doesn't blink that is 0.
4. Repeat step 3 for remainder codes, pressing 2 for second digit, 3 for third and 4 for fourth.
It doesn't state in the manual how to get out of this mode but normally it is either leave the remote alone for 5 minutes, or press any other button other than 1 to 4.
I have the radion shack hdtv remote. Cat no
Download the manual and codes from here
http://www.remotecentral.com/cgi-bin/files/dl.cgi?file=others/radio_shack/15135-manual.zip&area=other
Here is how to set the code...
1. Turn TV on
2. Press TV button on remote
3. Hold P button on remote until LED blinks twice
4. Enter the first 5 digit code for Magnavox TV's
5. Press Power button - TV should turn off. If TV doesn't turn off repeat steps 2-5 with the next 5 digit code, until either TV goes off or run out of codes.
6. If out of codes use searching for code method below...
TV codes for Magnavox
10047, 11454, 10054, 10154, 10000, 10250, 10051, 10180, 10060, 10030, 10171, 10092, 10706, 11913, 11904, 11755, 10019, 11365, 11254, 10802, 10386, 10282, 10020, 10187, 10186, 10024, 10179, 10096
Searching for code
1. Turn on TV.
3. Press and hold P button until LED blinks twice
4. Enter code 991 on remote - LED blinks twice
5. Press 1 - Device key blinks twice
6. Press Power button once
7. Press and release CH+ key until TV turns off.
At this point in the manual, the manual is only correct depending on what type of TV you have.
In the manual if you press the Power on button the TV should turn itself back on, the fail to state that not all TV's turn on by the power button, the majority now are triggered to turn on, on channel change, however you can't use channel change here to check it as you'll go to the next code... here is my solution...
8. Turn TV back on either using original TV remote, or buttons on front (most TV's if you change channels they come back out of standby mode, very few now turn on by pressing the power button).
9. Press Power button on remote - TV should turn itself off again.
10. Press P button on remote to lock in that code.
If the device does not turn off press CH- to go back through the codes, press and release P button when TV turns off.
Finding code
If you used the search function you might want to know what code it's using. To do this follow these instructions...
1. Press TV button
2. Press and hold P until LED blinks twice
3. Enter 990 and LED blinks twice
4. Press 1 and count number of times LED blinks this is the first digit of your code (e.g. 1 blink = 1, 2 blinks = 2, etc).
5. Repeat step 4 pressing buttons 2 - 5 for the other digits (e.g. for the second digit press 2 count number of blinks.. etc)
At this point the manual doesn't tell you how to get out of this mode, I presume pressing any other button on the remote other than 1-5 will take you out of this mode, either that or leaving the remote alone for 5 minutes.
Radio Shack 5 in 1 remote has no p button
NOTE: To program a TV/DVD, TV/VCR/DVD, or TV/
VCR Combo, use the TV key.
1. Turn on the device (for example, DVD player)
and, if needed, load media (for example, DVD).
2. On the remote, press a device key (that is, VCR/
DVD, CBL/SAT, or TV).
3. Press and hold P until the red LED blinks twice,
then release.
4. Enter the first four-digit code for your device.
The LED blinks once as each digit is entered. If
the code is correct, the LED blinks twice.
NOTE: If the LED does not blink twice, repeat steps 2
to 4 and try entering the code again.
5. Aim the remote at the device and press Power
(or Play, if it does not have a Power key). The
device should turn off. If it does not, repeat
steps 2 to 5, trying each code for your brand
until you find one that works. If you cannot find
a code that works, see “Searching for Your
Code”.
6. Repeat steps 1 to 5 for each device you want to
control. For future reference, write down each
working device code in a safe place.
27helpful
9answers
Enter codes for remote R55L8-RCR4358
There are 4 ways to program your remote:
-Brand Code search and entry
-Direct code entry
-Manual Code search and entry
-Auto Code search and entry
*ON TV/VCR(DVD) combos you must program each button individually and that button(ie. TV or VCR/DVD) will program that part of your device.
*the DVD/VCR button programs DVD by default, in order to program it for VCR you must put it into VCR mode:
1.hold down the DVD-VCR button-->the red led will stay lit.
2.while holding down the DVD-VCR button press the number 2 --> the red led will turn off
3.Release the DVD-VCR button--> the red led blinks 4 times and turns off
4.The DVD-VCR button is now set to VCR mode-->program for VCR
BRAND CODE SEARCH ENTRY:
1. turn on device
2. locate brand codes(sorry, I don't have it, try finding genaric RCA codes)
3. hold down the component button--> led should stay on
4. while holding component button, also hold power button--> the led will turn off, then after 3 seconds it will turn back on.
5. release both buttons--> led will stay on
6. enter brand code--> led blinks once
7. press power button repeatedly until component turns off-->each time you press the power key the remote sends a different code for that brand. led blinks once
8. if power on your device turns off press the stop button to save configuration-> led turns off
9. if the led blinks 4 times and turns off, you have reached the end of the codes for that brand, try using a different method to program your device.
DIRECT CODE ENTRY:
1. turn on the device
2. locate your device codes
3. hold component key down-->led lights up and stays lit
4. enter code while holding components key--> as first key is pressed the led turn off, then as 4th digit of key is pressed the led turns back on
5. release component key-->led turns off, try using your remote, if it doesn't have all of the functions you need, try a different code
6. if the led blinks 4 times after entering code you have entered an invalid code, try again.
MANUAL SEARCH AND ENTRY:
1. turn on device
2. hold the component button--> led lights up and stays lit
3. while holding component button hold power button-> led turns off then turns back on after 3 seconds
4. release both buttons--> led stays lit
5. push the power button a bunch of times until the device shuts off-> each time the power button is pressed a different code is sent to the device, the led blinks each time.
6. if the device turns off press the stop button to save your config.
7. if the led blinks 4 times you have reached the end of the code list, there are hundreds of codes, you may be pressing the power button for a while...
AUTO CODE SEARCH AND ENTRY:
1. repeat steps 1-4 of "manual search and entry"
2. press the "play" button--> led blinks 10 times, sending a code each time
3. continue pressing the play button until the device turns off
4. if the device turns off press the reverse key to until it turns back on then press the stop key to save config.
5. if the led blinks 4 times you have run out of codes, try a different method.
Now if someone would please post the codes, or if someone knows the code for a durabrand DVD-1002...
Mitsubishi VS-50607
This model is equipped with a self-diagnosis feature to help with diagnosis of shutdown problems. To activate this turn the unit on let it shutdown then press the input/device and menu buttons on the front panel simultaneously and hold them in for 5 seconds after 5 seconds the power LED on the front panel will blink a two digit sequence. This will be one set of blinks a short pause then another set of blinks, this will repeat 5 times. 1 - 2 = no error detected 2 - 1 = X-ray protect (high voltage or beam current) 2 - 2 = Short protect (short protect monitors low voltage supplies) 2 - 3 = Deflection protect (this could be loss of vertical or horizontal deflection) 2 - 4 = Vertical protect (usually loss of vertical from the source.
84helpful
15answers
Waste ink absorber on canon iP 1600
For Canon ip1000 and ip1600, maybe others
1. remove cartridges
2. unplug AC power
3. hold power button and plug AC power (keep holding power button.
4. press resume 4 times
The waste ink counter should be reset by now
Or
http://www.servicemanuals.ru/download/canon/ip1600.htm
4helpful
4answers
PROBLEM COPYING WITH MY ALL- IN- ONE
This message is inbuilt into most Canon printers, there is spongy thing in the printer which when fills up fires the message (it's mostly a counter in the printer, which can be reset more later...), per Canon this can only be dealt with in a lab but some of the more adventurous have tried cleaning it by themselves. Note that in a lab they won't clean it, it's a part that needs replacing and it might cost around $60. In most Canon printers there is a reset procedure that can reset the error and allow you to print some more before handling it again. Following are the reset procedures for some of the Printers: (not that F60 isn't listed here) Canon GENERIC "S" SERIES RESET CODE Waste Ink Counter Reset. (1) Turn off the printer. (2) Press and hold the RESUME button, then press and hold the POWER button. (3) Release the RESUME button, Next press and release the RESUME button two(2) more times in succession. Note: you are still holding the POWER button). The printer's carriage will "reset" or move momentarily. If the above was properly performed the printer will enter the "Service Mode". (4) Press the RESUME button 4 times, this will select the clear waste ink counter function. The lamp will alternate (change) color with each key press. 1. Service/Factory test printout, including ink sensor check. 2. EEPROM - Info printout. 3. EEPROM - Initialization. 4. Reset the Waste ink counter. 5. Printer model setting. (More selections beyond this point - However it is best leave them unaltered - You have been warned!) After selecting the desired mode (eg 4), press the POWER button to "set" the change, and return to the top of the function selection menu. Press the POWER button again to restart the printer. ++++++++++++++++++++++++++++++++++++++++++++++++++ Canon PIXMA iP1000 Waste Ink Counter Reset Manual for Service mode 1. Turn off the printer. And disconnect the printer cable. 2. Press and hold the POWER button, turn on the printer. 3. The indicator (L.E.D.) should be green. 4. Press and release the RESUME button , the indicator (L.E.D.) should be orange. 5. Press and release the RESUME button again, the indicator (L.E.D.) should be green. 6. Release both buttons. ++++++++++++++++++++++++++++++++++++++++++++++++++ Canon PIXMA iP1500 Waste Ink Counter Reset. Manual for Service mode 1. Turn off the printer. And disconnect the printer cable. 2. Press and hold the POWER button, turn on the printer. 3. The indicator (L.E.D.) should be green. 4. Press and release the RESUME button , the indicator (L.E.D.) should be orange. 5. Press and release the RESUME button again, the indicator (L.E.D.) should be green 6. Release both buttons ++++++++++ ++++++++++ ++++++++++ ++++++++++ ++++++++++ Canon i320, i255 Waste Ink Counter Reset. Step 1 : Manual Temporary 1. Unplug power and USB. 2. Open door and hold power button. 3. Connect power. 4. Close door, then release power button. or Step 1: Manual Temporary 1. Turn off the printer. And disconnect the printer cable. 2. Press and hold the POWER button, turn on the printer. 3. The indicator (L.E.D.) should be green. 4. Press and release the RESUME button , the indicator (L.E.D.) should be orange. 5. Press and release the RESUME button again, the indicator (L.E.D.) should be green. 6. Release both buttons. step 2 : Software for Permanant 1. Reconnect the printer cable. 2.Open General Tools software and select (USB PORT) 3 .Choose (SET DESTINATION 1) And it should be reset. Remark "After service mode Pls use software for permanent reset" ++++++++++ Canon i850, i950, S600 Start with the printer OFF 1. Hold down RESUME and then hold down POWER 2. release RESUME 3. press RESUME twice, then release POWER 4. Let green light blink until printer is done futzing Select function with RESUME press POWER to execute: presses - light color - function Number of presses - light color - function 0 presses - green - Test print (or exit service mode on i960) 1 press - orange - EEPROM info print (plus grid nozzle diagnostic on i960) 2 presses - green - EEPROM initialize 3 presses - orange - Reset waste ink counter ++++++++++ Canon S450 Printer 1: Power off printer 2: Hold Resume button then press and hold POWER, the beeper will sound once. 3: Hold POWER and release RESUME 4: Press RESUME twice 5. Release Power button 6: When the indicator lights steady, press RESUME three(3) times. The indicator should be orange. 7: Press Power to set data ++++++++++ Canon BJC 1000 Serie 1: Remove Cartridge 2: Unplug the AC Power Cord 3: Hold down the RESUME button 4: Release RESUME after plugging in the AC Power cord. 5: Press the RESUME once within 5 seconds and release the RESUME . 6: Press and HOLD RESUME for two seconds or more and release it. 7: Press and HOLD RESUME for two seconds or more and release it. 8: Unplug AC Power Cord to set data. ++++++++++ Canon BJC-2000 BJC-2100 Serie 1: Remove the Cartridge 2: Unplug the AC Power Cord 3: Close Front access panel 3: Hold down the RESUME/RESET button and plug in the AC power cord 4: Release RESUME/RESET after plugging in the AC Power cord. 5: Press the RESUME/RESET once within 5 seconds and release the RESUME/RESET . 6: Press and HOLD RESUME/RESET for two seconds or more and release it. 7: Press and HOLD RESUME/RESET for two seconds or more and release it. 8: Unplug AC Power Cord to set data. ++++++++++ Canon BJC-210 BJC-240 BJC-250 BJC-255 BJC-265 Canon BJC-4100 BJC-4200 BJC-4300 BJC-4400 BJC-4550 BJC-4650 Unplug Power Cord Hold POWER and RESUME buttons Plug in Power Cord Release buttons Open front door of printer Hold the CARTRIDGE and RESUME buttons Press POWER Release all buttons after the beeps Press CARTRIDGE once Press RESUME ++++++++++ Canon BJC-5000 1: Power off printer 2: Press and hold RESUME then press POWER, The indicator will start blinking. 3: While the indicator is blinking , Press RESUME twice then Wait until the printer beeps to indicate service mode 5: When the indicator lights steady GREEN, press RESUME four(4)times. The indicator should be GREEN. 6: Press Power to set data Service Test Print 1: Power off printer 2: Press and hold RESUME then press POWER, The indicator will start blinking. 3: While the indicator is blinking , Press RESUME twice then Wait until the printer beeps to indicate service mode 5: When the indicator lights steady GREEN, press RESUME two(2)times. The indicator should be GREEN. 6: Press Power to Print Nozzle Print 1: Power off printer 2: Press and POWER, until the printer beeps and release. Demonstration Print 1: While the printer in ON , , Press and hold RESUME until the printer plays a melody of beeps. ++++++++++ Canon BJC-5100 Self Test Switch Printer off. Hold Power for 1 beep. Waste Counter Reset 1: Power off printer 2: Press and hold RESUME then press POWER, The indicator will start blinking. 3: While the indicator is blinking , Press RESUME twice then Wait until the printer beeps to indicate service mode 5: When the indicator lights steady GREEN, press RESUME four(4)times. The indicator should be GREEN. 6: Press Power to set data Service Test Print 1: Power off printer 2: Press and hold RESUME then press POWER, The indicator will start blinking. 3: While the indicator is blinking , Press RESUME twice then Wait until the printer beeps to indicate service mode 5: When the indicator lights steady GREEN, press RESUME two(2)times. The indicator should be GREEN. 6: Press Power to Print Nozzle Print 1: Power off printer 2: Press and POWER, until the printer beeps and release. Demonstration Print 1: While the printer in ON , , Press and hold RESUME until the printer plays a melody of beeps. ++++++++++ Canon BJC-3000 BJC-6000 BJC-6100 BJC-6200 S400 S450 F300 F600 F620 Canon BJC-7000 BJC-7100 BJC-8000 BJ-F800 i6500 1: Power off printer 2: Hold Resume button then press and hold POWER, the beeper will sound once. 3: Hold POWER and release RESUME 4: Press RESUME twice 5: When the indicator lights steady, press RESUME three(3) times. The indicator should be orange. 6: Press Power to set data ++++++++++ Canon BJC-600 BJC-600e BJC-610 BJC-620 1: Unplug Power Cord 2: Hold POWER and FF and Print Mode buttons 3: Plug in Power Cord 4: Release after the beeps ++++++++++ Canon BJC-50 BJC-55 BJC-80 BJC-85 M40 M70 1: Unplug Power Cord 2: Hold POWER and RESUME buttons 3: Plug in Power Cord 4: Release buttons after the printers starts up 5: Hold CARTRIDGE and RESUME 6: Press POWER 7: Release all buttons after the beeps 8: Press CARTRIDGE 16 times 9: Press RESUME 10: Unplug the Power cord ++++++++++ Canon BJ-30 BJC-35v BJC-70 F14 Error Reset 1: Unplug adapter 2: Hold POWER 3: Plug in ADAPTER 4: Release POWER after printer starts 5: Hold FF and MENU and press POWER 6: Release after beeps 7: Press <> Cartridge until 1A is displayed 8: Press ONLINE 9: Press POWER to shutoff printer 10: Unplug printer then re-plug printer ++++++++++ Canon BJ F900, F890, F700, F500, S900, S820, S750 and S520 Turn off the printer. Press and hold the RESUME button, then press and hold the POWER button. Release the RESUME button, then press and release the RESUME button two more times in succession. (youre still holding the POWER button during this). The printer mechanics will move momentarily. You are now in Service mode. Pressing the RESUME key will select a function; for example, pressing RESUME 4 times will select the clear waste ink counter function. The lamp will alternate color with each key press. 1. service/factory test printout, including ink sensor check 2. EEPROM info printout 3. EEPROM initialization 4. Clear the waste-ink counter 5. Printer model setting. (more selections beyond this- leave this alone) After selecting mode, press the POWER button to commit the change, and return to the top of the function selection menu. Pressing the POWER button again turns off the printer for a resta ++++++++++ Canon S9000, S300, S400, i550, i560, i850, i860, i865, i9100, i9950, PIXMA IP3000 above, 1. Turn off printer 2. Hold down Resume button and press Power button. 3. Keep holding down Power button and let Resume button go. 4. Press Resume button 2 times then let BOTH buttons go. 5. Green lights will flash and then stop blinking. 6. When green lights are solid, press the Resume button 4 times. 7. Press the Power button and the printer should turn off, if not, press the Power button once more. 8. Your printer should respond as normal. +++++++++ Canon S900, S820, S750, S520 Turn off the printer. Press and hold the RESUME button, then press and hold the POWER button. While still holding the POWER button, Release the RESUME button, then press and release the RESUME button two more times in succession. The printer mechanics will move momentarily. You are now in Service mode. Release the Power Button. Pressing the RESUME key will select a function; for example, pressing RESUME 4 times will select the clear waste ink counter function. The lamp will alternate color with each key press. 1. Service/factory test printout, including ink sensor check 2. EEPROM info printout 3. EEPROM initialization 4. Clear the waste-ink counter 5. Printer model setting. (more selections beyond this- leave this alone) After selecting mode, press the POWER button to commit the change, and return to the top of the function selection menu. Pressing the POWER button again turns off the printer for a restart. ++++++++++ Canon S9000 Turn off printer Hold down Resume button and press Power button. Keep holding down Power button and let Resume button go. Press Resume button 2 times then let BOTH buttons go. Green lights will flash and then stop blinking. When green lights are solid, press the Resume button 4 times. Press the Power button and the printer should turn off, if not, press the Power button once more. Your printer should respond as normal. +++++++++ Canon MPC190 Reset Waste Ink 1) Enter SERVICE MODE. By pressing Menu Copy Scan Copy Copy 2) Select TEST MODE. 3) Select [8] PRINTER TEST in TEST MODE. 4) Select 3. [EEPROM CLEAR]. 5) Select 0. [INK COUNT]. 6) Press the [Set] key. 7) Press the [Stop/Reset] key (returning to the state of 3)), and then press the [ON/OFF] key.
Top Toshiba Computers & Internet Experts
ExpressFiX
ExpressFiX
k24674
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
