Question about Refrigerators
I have a GE refridgerator model number GSS25IFRE BB the ice maker and water dispensor just stopped working. The filter is new. and still has the problem with the plug in. Also if you hold a glass in the water dispensor the light above it pulses.
    President:
  • Refrigerators Master
  • 1,922 Answers
Do you have water getting to the filter? if not:first loosen filter and see if you might have air in line,secondly, the copper or aluminum water line from water supply to solenoid may be limed-up,third loosen line at solenoid and see if your getting water that far,those solenoids pulsate when operated on A.C.current you should hear a hum when activated to get water and that would explain pulsating light at water dispenser
Posted on Jul 24, 2009
6ya staff
SOURCE:
The ice maker stopped making ice. Any solutions?
A lot of filters ( not all ) do not even access the ice maker . Only the water dispensor . If your water dispensor is working fine , then you need to replace the dual water inlet valve behind the refrig . This is the piece the wall water line connects to . It is called a dual valve because there are 2 coils on the valve . 1 for the ice maker and 1 for the water dispensor .
Oct 23, 2009 | Kenmore Refrigerators
The water dispensor just stopped working today. The ice maker seems to still be working. What should I do?
I JUST CHANGE MY FRIGH FILTER BUT WATER DOSE NOT COME OUT THE FRIGH DOOR ONLY ICE. ITS A GE
Oct 02, 2009 | GE GSS25JEMWW Side by Side
GE PSS25MGMA Crushed ice only, nothing else will select on panel.
Yes , replace the main board . Part number WR55X10656 . There is only partial communication between the main board and the dispensor board . This main board , is behind the 8 " X 10 " panel , on the back of the refrig . Do not replace the dispensor board . I have never come across a bad dispensor board yet . Always a first time though .
Sep 27, 2009 | GE GSL25JFPBS Side by Side Refrigerator
ICE MAKER INOP
Check the water control valve on back and bottom of refrigerator. One side is for the dispenser and the other side is for the ice maker. When the ice maker begins a cycle the thermostat inside the ice maker begins to warm the bottom with a heating element to allow the ice to move freely and then dump into the container beside it. As the cycle reaches its final resting place a limit switch is pressed inside the ice maker to refill with water and start the process again. So if the water valve does not open and the tray remains empty and the ice maker will try to cycle again if the thermostat says that it is cold enough again. Check your model number again and I will try to get you some drawings. The number looks good but can't seem to pull it up. Let me know what you see and find. Try filling the tray with tap water and see if it will cycle after freezing. Thanks, Sea Breeze
May 20, 2009 | GE Refrigerators
No water from Water dispensor
Have you checked your water valve? I dont have your model number but you could have what you call a double water valve and one side of it may be out, alternately you may need to change your water filter if you havent done that yet. I have seen were the water stops dispensing first and then stops making ice. have you changed the filter lately? If not change it then if that doesnt work check water inlet valve...
May 12, 2009 | GE Monogram ZISS420NRSS 42" Built-In...
GE side by side refrigerator: water/ice dispensor
I bought a brand new smartwater replacement filter and after a very short time, my water stopped coming through the door.. took out the new replacement filter and inserted a brand new one .. problem solved.. apparently some of the g.e. smartwater filter replacement cartridges don't have the high enough two plastic inserts which are attached to them at the top of the filter when you screw them on... if you have taken your cartridge in and out a few times, i think it wears down the plastic so it doesn't fit properly and won't put up whatever it is supposed to push up to make the water come through.. I personally think this is a g.e. problem with the replacement filters...
Jan 31, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
Water dispensor not working
Did you use the correct filter?
Remove filter, and re-install. Make sure you have properly locked the filter into place as the locking mechanism assures the filter cut off valve opens.
Also, make sure any air was purged from the water circuit by holding the water valve open for a short period of time.
Jan 30, 2009 | GE Refrigerators
Ice maker not working
The solenoid on the back is not working or the ice maker is not calling for water.(check the solenoid first)
Jan 15, 2009 | GE Refrigerators
GE PROFILE PSS26msrd Ice maker not working water dispensor ok new water valve new filter fill tube seems clear Does anybody have any sugestions before i replace the ice maker unit?
water does become ice inside the pipe in side the freezer it happens to my frige at list once a year, put a hard wire or pencil up to make sure that is not the problem, before you spend any more money
Dec 06, 2008 | GE Profile PSW26P Stainless Steel Side by...
GE Refrigerator, model PSS26MGPBBB, stop making ice. Water dispensor works fine. Green light on ice maker is blinking. Have tried recycling power to ice maker no change. Have check to see if...
PROBLEM IS ASSOCIATED WITH THE TEMP SENSOR INSIDE ICE MAKER. I HAVE TRIED TO FIND THE PART, BUT WITH NO LUCK. IT LOOKS LIKE WE WILL HAVE TO PURCHASE A NEW ICE MAKER.
Aug 25, 2008 | Refrigerators
Refrigerators Logo
228 people viewed this question
Top Refrigerators Experts
John Tripp
John Tripp
Marvin
Marvin
