Question about Sansui Televison & Video
Our HDLCD3250 Sansui (in our RV) will not receive a digital signal. I've called the 800 number and she said some of these Models came without QAM 256. Will a digital to analog converter box help?
6ya staff
SOURCE:
Anonymous
SOURCE: ZENEITH DTT900 ANALOG TO DIGITAL CONVERTER BOX CONNECTIONS
Can't go through the VCR in the normal way. The DTV box must be tuned to the channel you want to record and left there. Cannot tell VCR to tape one channel and watch another nor tape multiple timed and multiple channel shows unless the DTV is tuned to that specific channel. This makes most VSR functions useless.
Posted on May 28, 2008
Anonymous
  • 948 Answers
SOURCE: Converter Box Problem
That just means that stations you can't pick up while the box is on are not broadcasting digital signals yet. Most will be after February.
Posted on Jan 01, 2009
SOURCE: Is my Toshiba TV digital or analog?
if there is a label on the tv stating any of these words “Integrated Digital Tuner,” “Digital Tuner Built-In,” “Digital Receiver,” or “Digital Tuner,” “DTV,” “ATSC,” or “HDTV” then yes
if they say “Digital Monitor” or “HDTV Monitor,” or as “Digital Ready” or “HDTV Ready" then no
Posted on Jan 08, 2009
Anonymous
SOURCE: I have a TB110MW9 DTV
just a note. that you may want to go near the box while holding the setup button. also, it may take more than 3 seconds for it to respond. during tests. it could take up to 20 seconds for response. but this does solve the RF OUT for sure. hope this helps
Posted on Apr 03, 2009
Anonymous
  • 87 Answers
SOURCE: QAM Tuner difference between Toshiba & Samsung
software upgrade available from toshiba.
Posted on Apr 24, 2009
Ematic AT102 How do you program it to receive the cable channels when no cable box is needed?
Unfortunately, the Ematic AT102 does not have a tuner for cable television. It only has a ATSC (digital over-the-air) tuner. You need to connect it to an TV antenna and then search for channels. Depending on where you live, you may need an external antenna to get sufficient signal strength to receive local channels. See http://www.tvfool.com for signal strength information in your area.
Older cable signals are NTSC (same as analog over-the-air). Newer digital cable is QAM. (Some channels are broadcast as clear QAM which don't need a cable box with some tuners/TVs.)
To record your cable, you will need a different type of DVR/set-top box. An old VCR or DVD recorder with an NTSC tuner would work to record analog cable. There are a few ATSC converter boxes that also support clear QAM. This is one of the models: http://www.solidsignal.com/pview.asp?p=CM-7003 .
I wish that I had better news for you. Other options are available for NTSC, ATSC or QAM tuners. Please add a comment with more information about your cable service if you'd like extra information on these options.
Feb 23, 2017 | Televison & Video
Stop receiving cable channelsWhy?
Your cable company may have switched from Clear QAM signals to to digital signals. This forces you to pay them a set-top-box rental fee. Read more about QAM and FCC rules here:
FCC Rules To Make It Harder To Get Cable Channels Without Cable Box
Dec 07, 2015 | Televison & Video
What is the symbol rate of 256 QAM?
Without knowing the bit rate, you would not be able to calculate the symbol rate; and without the symbol rate you would not be able to calculate the bit rate.
Based on the below referenced web sites, you can see that the symbol size for 256 QAM will be 8 bits without considering error detection/correction. The QAM value is determined by taking the number of bits/symol and rasing 2 to that given power.
8 bits/symbol => 2^8 => 256 QAM
Simple definition of 256 QAM
256 QAM dictionary definition 256 QAM defined
Comparisons of different QAM to demonstrate bits/symbol to QAM ratio
Comparison of 8 QAM 16 QAM 32 QAM 64 QAM 128 QAM 256 QAM Types
Oct 15, 2014 | Electronics - Others
How can i get a QAM code?
QAM codes are to do with the way digital TV is encoded. There's nothing practical you can do with a QAM code. It's like understanding how to calculate the mass of Jupiter. Great that you can do it. But it's of no practical day-to-day benefit.
Here's some reading on Quadratic Amplitude Modulation, for what it's worth.
Sep 08, 2014 | Seiki Televison & Video
Won't turn on after unplugging sansui
Leave it plugged in for about an hour for it to warm up than it will work like normal. I have this problem every once and a while
Feb 02, 2013 | Sansui HDLCD3250 32 in. LCD TV
Sansui HDLCD1908B Television
call you digital cable provider
Jul 23, 2012 | Sansui HDLCD1908 19 in. LCD TV
DO THE DCT700 CABLE BOXES HAVE AN TV TUNER BUILD INSIDE THEM?
RTFM!
  • MPEG-2 digital video processor
  • ATSC standard Dolby® Digital (AC-3) Audio Processor
  • ITU standard 64/256 QAM/FEC enhanced adaptive equalizer
  • On-board real-time RF return (256 Kbps)
  • Bitmapped graphics display (4-/8-bit)
  • 90-860 MHz Tuner
  • DES-based encryption DCII access control
  • Digital diagnostics
  • Frequency agile 2.048 Mbps out-of-band data receiver
  • Macrovision copy protection
  • IR support for remote control
  • RF remodulator output (ch. 3, 4)
  • Baseband video and audio outputs
Jul 20, 2010 | Arris DCT700 DTV Receiver
Digital Conversion for DFTV270A
A VERY short search on Google (first hit when using "DFTV270A digital") shows this:
Amazon.com: SANSUI DFTV270 27" Flat Digital TV with ATSC/QAM Tuner ...The DFTV270 receives digital terrestrial and cable signals without the need for an additional tuner.
People should at least make a minimal effort in looking up answers for themselves. An equivalent questions is asking if a FlexFuel can use E85 gas.
Jan 18, 2009 | Sansui Televison & Video
Analog/Digital
HDLCD2600 come set for cable. Make sure the tv is set for "tv" or "air" then run the auto channel memory or search feature of the set. If you have the manual it's under "memorizing channels". If your still have problems, call Sansui TV's customer service number 800 289 0980.
Nov 04, 2008 | Sansui HDLCD-2600 26 in. LCD Television
Televison & Video Logo
44 people viewed this question
Top Sansui Televison & Video Experts
matt martin
matt martin
Ekse
Are you a Sansui Televison and Video Expert? Answer questions, earn points and help others
