Question about Toshiba Televison & Video
Hi, my Toshiba Tv has two hdmi ports both of which are broken. I believe they need soldered back into place. My question is where can I get this done professionally and how much would the cost be
  • Toshiba Master
  • 2,195 Answers
Any competent electronics repair service
as you don't specify an area to give a suggested engineer to use
Posted on Apr 23, 2017
6ya staff
SOURCE:
How do I replace hdmi connectors in tv
If your television is under warranty, have the manufacturer repair or replace it for you. If your TV has more than one HDMI port, you can use an HDMI splitter to connect multiple inputs to the one port. However, if you are confident in your soldering skills, you can repair broken HDMI port, so long as the damage is only to the connector and not to the printed circuit board to which the port is soldered.
Jan 18, 2015 | Hitachi 42PD9700 42 in. Plasma Television
Seeking Parts Advice for Broken Samsung TV
I would also just buy a new board .BUT keep the old board for parts! This way if anything goes out you can compare components on the board etc and figure out what's wrong and also use the parts for repairs when you need them. Some of those boards HDMI ports have the tiniest solder joints and you can easily bridge them make the board useless anyway. These things are way more fragile than the old CRT tv's. Just be a little more careful next time.
Dec 30, 2012 | Televison & Video
How to connect sony ps3 to toshiba 32av500a
Use any HDMI cable to to this.
Connect cable to the "HDMI" port on the back of the PS3. Connect the other side of the HDMI cable to the "HDMI" port on the Toshiba TV. If the Toshiba TV has multiple HDMI ports, make note of which port you plugged the HDMI cable into.
Change the Toshiba TV to its "HDMI" video display mode. Press the "Power" button on the PS3 to turn the console on. The PS3 will automatically detect the HDMI cable. Select "Yes" to use the audio and video from the HDMI cable. Select "Yes" to have the PS3 automatically use the optimal settings for the Toshiba TV. Select "Yes" to accept the recommended resolution. Press the "X" button to save the settings
Dec 22, 2012 | Toshiba Televison & Video
I need to know how to hook up my PC to my TV.
I understand that you want to hook up your laptop to your TV. I believe your laptop has an HDMI port, then supposing that your TV is HDTV right? Well, if they are both HD capable nothing to worry about.
If you don't have an HDMI cable yet, I would advise to buy one. Once you have it, all you have to do is..
1. Plug the Other end of your HDMI cable to your laptop HDMI port.
2. Then the other end of the HDMI cable plug it to the HDMI port of your TV.
3. From your TV remote control, press Input/source, then there will be a drop down menu option, select "HDMI" once you select it you are good to go.
I hope you find it very helpful. Thank you for using fixya.
Aug 13, 2011 | Toshiba Satellite A105 Notebook
Both HDMI ports are bad due to lightening strikes. What do I need to do to fix this? Can you suggest part numbers?
The main tv Tuner signal board have problems and all those HDMI insert ports are shorted dead,those HDMI insert ports are put on by wave soldering machine and fused by iron core solders joints to the main tv Tuner board itself.These HDMI insert ports are not replaceable by hand soldering equipments or can buy those HDMI insert ports individually anyway.Tv still work wright?Yes? Why don't u just skips the used of those HDMI insert ports all together and tries used those RCA component cable connections like AV1 and AV2 on the tv.Or u must have some mechanicals skills and like take things aparts and putting back together again?Yes?Tries websites like Shopjimmy.com,Ebay.com to buy a whole refurbish tv main Tuner signal board for the replacement to able to used those HDMI insert ports again.I have the same problems with my Samasung 46" all my HDMI insert ports are dead too,but the tv still functions.That what i did used RCA cable components connections for my cable box and blu Ray player.
Aug 03, 2011 | Sceptre X42BV 42 in. LCD TV
I have a 37" Insignia L37Q tv with 4 HDMI inputs. Only HDMI 1 works properly. If I hook up an HDMI device to any of the other HDMI ports I get one of the following: 1. No signal 2. Not supported 3....
Try plugging hdmi cable into hdmi 1 on your TV, then open the menu on TV and find the place it lets you to make selections on this, such as Satellite or hdmi 1. One of these selections have to work.
does the hdmi port gets detected when you try in other hdmi ports.if not getting detected then it can also be fault in the hdmi ports.because as you said that hdmi port number 1 works.that means wires are proper.but other hdmi ports not working that means the ports are faulty if all the setting are proper in setup.
as the ports are soldered to the unit internally.if the soldering gets loose the connection will not get complete.so re-soldering is required to the loose ports.
if you are not familiar with doing this you can get it done by local repair technician familiar with this model .
This will help. Thanks please keep updated.please do rate the solution positively .thank you for using fixya.
Nov 16, 2009 | Insignia NS-LCD47HD-09 47 in. LCD TV
Have a Toshiba 42hm66 tv. The HDMI port has quit
The best thing to do is to call Toshiba at 1800-631-3811 and see if they could refer a Service Facility to you to check it out. I would guess that that Board that has the HDMI Port on it needs to be replaced but it is not a easy or simple job.
I hope this helps,
Skyassoc
Sep 17, 2009 | Toshiba 42HM66 42" Projection HDTV
"No Connection"... My first attempt with HDMI SUUUUCKS- HELP
The connector board inside the tv is the one has circuit traces already broken. there is nothing outside the tv can be done. The HDMI conector is high end technology solder. finally the solution is to replace the conector board inside the tv.
Jan 02, 2009 | Samsung HL-P5063W 50" Rear Projection HDTV
Televison & Video Logo
Top Toshiba Televison & Video Experts
matt martin
matt martin
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
