im looking for a viewsonic remote control the "RC00071p-1E"
do you know ehere i could purchase one of these? or if a universal remote would work.
thanks
Yes you can purchase the remote from Viewsonic Online Parts Store or I have seen them for sale at remotes.com and that 3rd party store gives a 1 yr. warranty unlike VS 90 day warranty on the remote. As for the remote codes, Viewsonic does not have any since the universal remote comes furnished with a code book from the "MAKER" of that Universal Remote. I have heard that the Philips TV brand codes for universal remotes work on quite a few series' of Viewsonic TV's, so try those from your code book.
Bought my ALBA L42M1 from argos, had same problem, phoned there helpline and they said using the origional remote hold down menu for 10 seconds then press menu again to reset remote. It worked for me. hope this helps
After bying my second viewsonic remote, that lasted 7 months,the company discontinued my model #.frostrated i've decided to do it my way.i took the remote apart,cut off the rubber push button that was not working,than i cut off another push button that i had no use of and voila' made the switch and my remote is working like new again($free).you should be able to do the same and save yourself a trip to the online expensive betting stores.
do it today!
eddie
You can email your request for replacement parts to [email protected] and provide the product model, serial number, and your contact information with shipping address (U.S. and Canada only please).
You can also purchase parts online at the ViewSonic Store.http://store.viewsonic.com/html/ibeCCtpSctDspRte.jsp?section=
Hi, please advise remote control codes for viewsonic and info about digital turner?
Try visiting the part store the following link, make sure you have the correct serial number. http://www.PartStore.com
Also to buy universal remotes try visiting http://www.ilektroniks.com
Thanks
SOURCE: How do I program a RCA universal with ViewSonic tv?
Here, try this link:
http://www.ehow.com/how_9191_program-rca-universal.html?ref=Track2&utm_source=ask
If the method you used is different from what is suggested on this link, try pressing "enter" or the like and see if it works.
I hope this helps!
Sincerely,
Der Strom
SOURCE: need remote code for viewsonic rc00136p remote
hi! i have here a couple of codes for your Viewsonic tv, just try them, 1038, 1149, 1180, 1181, 1182, 1183, 1184, 1185, 1186, 1187, 1188, 1189, 1190, 1205, 1206, 1441, 1361, 1489, 1495, hope this helps!!!! goodluck!!!
SOURCE: I have a ViewSonic RC00136P remote control. It
Okay here's the fix.
Remove batteries. Re-install them wrong side
in! Don't panic.
Reverse the direction of both the battery cells and
install. Press "Power" button a couple of times and a few other
buttons a few times. Then remove batteries and re-install the right
side in.
Voila.
ive tried these but neither have the remote any other suggestions?
Thanks,
Hannah
