Ladies Gucci 11/12.2 watch: how to open? (looks like back may twist off with special tool)...
Most watches are either screwed on and typically have a series of small notches around the circumference of the case back. A special tool is generally called for. Otherwise they are "snap back" . These are simply pressed on. To remove you can carefully use a regular knife in the absence of a "case knife". There is usually a small gap/groove/notch area to insert the balde and lift the back off.
