I have a singer inspiration 4212 and I want to use blind hemming (if possible) on a fairly thin material. Can you please show me what settings I should use
The blind stitch would look like a couple of straight stitches and then a :"V" shaped zig-zag that will zag left to catch the very edge of the folded fabric.
here's the manual:
http://homeappliance.manualsonline.com/manuals/mfg/singer/4212.html (pgs 55-56)
SOURCE: Fabric Guide
The above is a picture of the fabric guide in use; it slides into top portion of your presser foot shank. It can be used in either direction for
guiding uniform stitch lines.
Hope that helps! Happy sewing!
SOURCE: How many foot for Baby lock E5280 like flat, blind, rolled hem?
i dont have a baby lock but on my machine i change from rolled hem to flat needle plate
or change setting to n from r also loosen lower looper tension as rolled hem requires a tight lower looper tension.
hope this helps you
mary h
SOURCE: Need to know how to set the tension to sew hems on
Re-thread the machine and make sure that the needle is in properly. The tension would not cause the thread to break.
If it is not working, what is the machine doing? Try re-threading the
machine again, check the needle to make sure that it is in correctly.
There are no set numbers for tension- it is a feel, push, pull. If you
could e-mail me back with a better description of what the machine is
doing or not doing,
SOURCE: what are the settings for a blind hem stitch?
I downloaded your manual for free at www.singerco.com and I be darned, I see why you are baffled. Call Singer at 1-800-4singer and ask them to tell you. This is a first for me to see in a machine that is not that old, my 45 year old Kenmore has the blind stitch setting. There has to be some answer to this.
