Hi there remove the memory card and reset the camera. Now turn on the camera with out the memory card and make the camera flash light ON mode and take a snap. If the flash not working after this setting, then you need to replace the flash tube. The flash tube is cut off and thats why its not working.
At this price point, they really are not worth investing time and labor required to attempt repair. Sometimes it simply makes more sense to dispose of the old and purchase new.
Does the flash fully charge? If so, it may be that the flash tube is faulty and will require replacing.
This should be done by your authorised Samsung repair centre.
It's not the camera.
Are your batteries suggested for digital camera use? Have you checked the expiry date?
this camera is quite the battery ****- even if your batteries show up as fully charged, a lot of brand's don't have enough power to support this camera, so MAKE sure you buy good batteries.
I have this camera and mine did the same thing. YOU SHOULD DEFINATELY TRY DOUBLE AA RECHARGEABLS. I know you probably have ehard that they're no good, bubt my camera works for days if i fully charge the batteries, So, try some new and FRESH batteries for your camera.
Dont use Ni-cd batteries, only NiMH or the new "Oxy" batteries from Panasonic, 5X the power of Alkaline and higher voltage, GREAT disposable battery for a Digi-cam. Some cams will NOT work on the old zinc batteries, even brand new. Fun mode is probably just to edit anyway, probably not a shooting mode.
- Pressing MENU/OK button
- Scroll to the right until you are in SETUP 2
- Keep on scrolling down and look for battery type
- Press the right button to pick up on 2 options
like Alkaline and Ni-MH
- Press MENU/OK for changes to be saved
- Keep pressing MENU/OK to get out of the MENU
Once, it's done, camera needs to be turned off for a few seconds
so that settings made will be refreshed with the camera.
As you turn camera on, you're now ready to take many pictures.
ALKALINE (Non-rechargeable) batteries when set to the correct battery type will really take a maximum of 100 pictures.
For the Rechargeable batteries (Ni-MH), when those are fully charged, and the battery type is set to Ni-MH, it will be taking more than a hundred of course.
