SOURCE: tv will not turn on
your tv needs to be repair again power supply problem or circuit.good luck.
I have a two month old red max weedwacker that just decided to start shutting off when i give it gas. I hold idle no problem. Aircleaner=good, spark=checked, primer=good, dumped fuel and got same problem, I am upset because when redmax hit the scene with the backpacks they were solid. I just replaced a magneto on a year old red max blower and I am waiting on a crankshaft for a redmax set of gas shears: I hit a fence and in the past with other companies shears that was not a major problem. The redmax shears crankshaft broke and sheared two bolts of hardened steel on an irregular, recessed angle in the aluminum housing. After shelling out 450 bucks i am not the happy camper. I went old school and bought electric little wonders--know what: I forgot what a pleasure they were: light and no fumes. Any helpon the whip would be greatly appreciated. TOM 39 accounts long island ny
SOURCE: onan genset worked fine a week ago
is it an electric start?...if so check battery and/or look for loose battery cable..Ground?...vibration during use could have loosened the cables...the make ready people sometimes do not tighten properly
SOURCE: i bought HP Pavilion dv5 6 months ago and fan not working
Your cooling fan sounds to have went out,causing it to overheat and shut down.It also could be something in the fan stopping it from turning.Try cleaning it or blowing it out with it off.But it mostly sounds to have went out.
SOURCE: my mitsubishi 60
This is a very common failure on Projection sets. Its called a convergence problem.
You may have one or more of the following symptoms.
You can see some examples and find a fix here...
http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
