I bought this printer to specifically print out brochures which I need without borders. Can this printer even make borderless prints?
SOURCE: Problems with Kyocera Mita FS-1920
Make sure that your paper sizes match in the control panel of the printer in Windows. It will not only cause the duplex not to work but could cause jamming problems as well. When printing in duplex mode, make sure it is turned on.
SOURCE: Printer will only print page 1 of multiple page documents
1. Check that you are using the latest print driver - from kyocera website.
2. If the issue is when you print pdf files then make sure you set the printer in KPDL Auto mode - check the print driver settings about this and the printer menu.
3.You may check if you have the latest firmware installed within the printer - print a service status page (Menu->Others->Service).
SOURCE: Kyocera FS-c5030N printing pages yellow
Push in the charge corona assy. Its behind the left door. Each color has a cleaning rod and charge assy. I've seen this more than once.
SOURCE: My Kyocera FS-C5030N is printing blank pages
there are a good few possibilities... your cheapest route is to call a local service tech... anything I tell you is going to cost you more... call him and see what he says... but I am leaning towards bad ram best case and worst case a blown main board...
I’m happy to assist further over the phone at https://www.6ya.com/expert/norman_d2fa496dce30c65d
SOURCE: KYOCERA FS C5030N PRINTS ONLY THE FIRST PAGE OF A
make sure you are using the KX PRINTER DRIVER first
if so..
tray changing the pdl format
in the printers and faxes area right click on your printer
right click go to properties.
click on device settings tab (you have this if you are using the KX driver)llhopefully you are
you will see a button (pdl) click on pdl
changed pdl to pcl5e
good luck
