Computers & Internet Logo
A
Anonymous Posted on May 20, 2017
LG R460 touchpad is erratic - LG Computers & Internet
Erratic touchpad
Update the drivers for the touchpad, OR you can change the speed of touchpad by going to Control Panel. I mean seriously, do you people even READ?
1helpful
2answers
Runaway touchpad on HP laptop.
I have the same problem. An external mouse does not behave erratically. If the touchpad is wearing out, will a replacement touchpad solve the problem, or does the circuit board need replacing?
Notebook Samsung R460 . I need a hard disk driver. Thank's
Go to this link: http://www.samsung.com/hk_en/support/detail/supportPrdDetail.do?menu=SP02&prd_ia_cd=&prd_mdl_cd=&prd_mdl_name=NP-R460 Choose the download tab, and there the drivers tab. You'll find the necessary drivers. If not, install the chipset drivers, it might help. Good luck!
1helpful
The typing goes haywire the cursor moves erratically particularly with Google chat google mail etc
in control panel, mouse, touchpad tab, there should be options to either:
Disable touchpad while typing
or
Enable Palmcheck
these settings should resolve the issue, if you don't have these or similiar options, then download the latest touchpad driver from Support.dell.com
2helpful
2answers
Cursor on my keypad jumps around
If your cursor moves erratically on the screen (for example, if it jumps around the screen, moves at varying speeds, or selects items on its own), perform the following steps:
1. Clean the surface of the touchpad with a dry, soft cloth to remove grease, sweat, moisture, or other liquids.
2. Adjust the sensitivity of the touch pad:.
a. Click the Start button and click Control Panel.
b. Click Printers and Other Hardware.
c. Click Mouse.
d. When the Mouse Properties window appears, click the Pointer Options tab.
e. Under Select a pointer speed:, click to move the slider bar closer to Slow.
f. Click OK.
g. Check to see if the touch pad still behaves erratically.
3. If the touchpad still caused the cursor to behave erratically, attach an external mouse to your computer and restart your computer. Use the external mouse to see if your cursor still moves erratically.
4. After connecting an external mouse, uninstall the touchpad driver from the Device manager listed under the "mice and other pointing devices" category and restart the Computer.
5. Download the Touchpad driver compatible to the Operating System installed on the Computer from the manufacturer's site and install it after restarting the Computer.
Good luck!!!!!!!!!!
1helpful
Inspiron 1525 Touchpad has a mind of its own
I would try using what they call a cool mat. It sits under your computer and plugs into your computer per USB. It helps keep the computer cool. They cost like 25 dollars.
Dell Inspiron 6400 PC Notebook-touchpad working erratically,help!
i cant figure out how to turn on the croll for my inspiron 6400 touch pad
Erratic Touchpad on Toshiba M50 Notebook
if the touchpad is working fine with the battery and if it is not working with the ac adaptor then in this case u can try with the different ac adaptor and still if it does the same thing then uninstall and resintall the toouchpad driver and restart the computer and still if it does so with the ac adaptor then u need to open the laptop chasis and then u need to fix up the power supply connector in the motherboard where the power supply from the ac adaptor is not getting the adequate response from motherboard.
Top LG Computers & Internet Experts
k24674
Grand Canyon Tech
Grand Canyon Tech
Are you a LG Computer and Internet Expert? Answer questions, earn points and help others
