Computers & Internet Logo
B
Busaphi Dladla Posted on May 22, 2017
ASUS startup sound but no picture (and no windows startup sound). If I leave it on sometimes the startup sound will sound again. The day it died on me it had done a weird split black screen,
1 Related Answer
Anonymous
  • 381 Answers
  • Posted on May 10, 2009
SOURCE: Black screen startup
hello..this is the 1st you need to try..if you have a CRT monitor or LCD Screen try to put the signal Video on the Laptop located at the Back of unit then try to boot your unit...Thanks...
USB ports work sometimes and sometimes they don't.
Sounds like a drivers issue. www.driveragent.com is a reliable scanner and source of real drivers. There is a small cost involved.
tip
Good day PRO, I WAS TRYING TO INSTALL WINDOW 7 ON MY Asus Eee PC...
Acer Aspire one Windows 7 password problem usually can be met by our Aspire laptop users! It is actually troublesome for us! How can we solve <b><a href="http://windowspasswordrecovery.net/">Acer Aspire password reset</a></b> quickly and easily? Then we will search solutions online now - <b>Aspire one password reset</b> urgently!<br /> <br />A. For <a href="http://windowspasswordrecovery.net/article/acer-password-reset.html"><b>forgotten Aspire Windows 7 password</b></a> problem, we can recover password with <b>Aspire password reset disk</b>:<br /> 1. After wrong password prompt displays, click "OK" - "Reset Password";<br /> 2. Insert the password reset disk into PC driver, click "Reset password" and the Password Reset Wizard will comes up, then "Next";<br /> 3. Choose the targeted password reset disc from drop down box, and then click "Next";<br /> 4. Input and confirm newly set password, then "Next" - "Finish", close Password Reset Wizard.<br /> <br /> Please <b>note</b> that the Acer Aspire one Windows 7 password reset disk can only be useful if we created it before we lost password. Now, it is not late to generate a password reset disk for our account. We also can share it with our much more friends!<br /> Step 1. Power on <b>Aspire Windows 7 laptop</b> and login;<br /> Step 2. Insert prepared bootable USB Flash Drive;<br /> Step 3. Click Start -&gt; Control Panel -&gt; User Accounts and Family Safety -&gt; User Accounts -&gt; Create a password reset disk -&gt; Next;<br /> Step 4. Choose the inserted Flash Drive and click "Next";<br /> Step 5. Input login password and click "Next";<br /> Step 6. Click "Finish" to exit once progress indicator displays 100% complete, and then remove the disk from laptop.<br /> <br />B. For <b>Aspire one Windows XP password</b>, we can unlock password from Safe Mode:<br /> With the default administrator account, we can use it to recover lost Aspire XP password quickly.<br /> Step 1. Press "F8" when power on Aspire laptop;<br /> Step 2. At Advanced Boot Options window, choose "Safe Mode" and press Enter;<br /> Step 3. Choose and Click the "Administrator" account at the Windows logon screen;<br /> Please note that if you've ever set this administrator password, you need input the password set before. If not, you should keep the "Password" blank.<br /> Step 4. Click Start -&gt; Control Panel - user accounts -&gt; Select the account needed to reset password -&gt; Input new password.<br /> <br /> C. For <b>Acer Aspire Windows Vista password unlock</b>, we can use free tool - Ophcrack<br /> We can download the Ophcrack and burn a password reset disk to remove Aspire one Windows Vista password!<br /> <br />D. For <b>Acer Aspire one Windows Server domain password</b>, the most efficient way is to refer to professional <a href="http://windowspasswordrecovery.net/"><b>Windows Password Recovery Corporation</b></a>: <br /> Step 1. Burn a CD/DVD/USB Flash Drive to reset lost or forgotten Windows domain password;<br /> Step 2. Set your locked PC to boot from CD/DVD/USB Flash Drive;<br /> Step 3. Reset forgotten Windows domain password to new password with the burned CD/DVD/USB Flash Drive.<br /> <br />Feel at ease even we <b>forgot Acer Aspire password</b> or Aspire one on any OS with vital data on PC, <b><a href="http://windowspasswordrecovery.net/">Aspire one password reset</a></b> is still simple for us!<br /> <br />Source: http://windowspasswordrecovery.net/article/acer-aspire-password-reset.html<br />
on Jul 21, 2011 • Computers & Internet
tip
"Help!!! How to recover my forgotten laptop password?" Situation is so urgent! Then search solutions online: laptop password reset, how to remove laptop login password? Carelessly, we forgot laptop password, then we now concentrate on how to unlock laptop password methods!
How do I recover laptop password on Windows Vista?
- Remove laptop Windows Vista password from Safe Mode
A. When laptop starts, please press "F8" key.
B. At the "Advanced Boot Options" windows, choose "Safe Mode with Command Prompt" and then login Safe Mode with available administrator account
C. Input "net user", press "Enter" key and then all the accounts will be listed.
D. Input "net user Lisa 012" (Lisa is the forgotten account name and the 012 is Lisa's related account password.), press "Enter" key to finish unlock laptop Vista password.
E. Input "shutdown -r" and press "Enter" to restart laptop, then we can login "Lisa" account again.
How to find laptop password for Windows 7
- Bypass laptop Windows 7 password with built-in administrator account
A. Power on laptop PC and press the key: F8.
B. At the windows of Advanced Boot Options, opt for "Safe Mode with Command Prompt" and confirm with key: Enter. Then PC starts Windows.
C. Select "Administrator" account shown on the account screen, and then access the windows - Administrator: cmd.exe.
D. Input command: net user Merry 123 and confirm with Enter. (Merry is the account required to reset password; 123 is the new password for account Merry).
Please note that the administrator account will be useful only we had set it enable. (The default status is disable.)
How can I Break password on laptop Windows XP
- Get into Windows XP laptop by default Administrator account
A. Press "F8" when laptop computer starts.
B. At the "Advanced Boot Options" windows, choose "Safe Mode" with arrow key and confirm with Enter key, then PC accesses Safe Mode.
C. Click "Administrator" on the Windows login screen.
Please note that if we have set the Administrator password before, we need to input the changed password instead of leaving "Password" field blank.
D. Start - Control Panel - User Accounts - Select the locked account and change password for it.
E. Restart laptop and login with the account newly reset password.
The above ways are referred to system with available account (default/built-in account or other accessible accounts with administrative privileges). While, if there is not other accounts to help us, how to reset laptop password?
Unlock laptop password with Installation disk: if there is not important data for us, we can use it for password unlock.
Laptop password bypass with password reset disk: we can use the disk only if we create the disk before lost password for the related account.
DIY a laptop password reset disk now: It is the last but not the least solution on laptop password recovery!
We need a CD/DVD/USB disk and an accessible computer to burn a .iso image file from Windows password recovery software! Take one of the most top-rated tools - Ainorsoft Windows Password Recovery Corporation as example:
A. Download Ainorsoft Windows Password Recovery Corporation and burn its .iso image file into a CD/DVD/USB Flash Drive from an accessible laptop;
B. Set PC with password locked to boot from burned CD/DVD/USB Flash Drive;
C. Reset forgotten laptop Windows password to a new one with the burned CD/DVD/USB Flash Drive.
Now, once we forgot laptop password, the last method will always make sure we reset password for laptop easily without IT expert knowledge.
Source: http://windowspasswordrecovery.net/article/laptop-password-reset.html
Asus c90s pc notebook got a new battery and now when you plug in to the charger it flashs an orange light and when you try to turn it on it wont and the green light on the chrager dies?
just remove the battery and connect it again. connect the power cord and leave it for 10 minute and try after 10 minutes switch on the button.
Hope this helps. Please rate my response.
Thanks.
Have a good day
2helpful
My notebook Asus W7J BLANK when is turn on
Screen not working
are you able to hear the windows log in?
if you do but no image, most likelly your video card is ruined. overheated or dropped maybe? don't worry is bad but not that bad, there is a way to fix that by a professional.
take it to a computer repair shop and have them check the video card ask if they have a rework station or someone who may. they have to unsolder about 50 pins at the same time get a new card and solder it again.
sometimes they apply heat to it and it will work again but for just a few days maybe weeks but it goes bad again. so replacement is the best option.
I used to charge about 200 bucks but you may be able to ask for a rebate.
do not take it to a major computer store they would tell you there is no repair so you can go in and get a new computer
The sound card only loads at startup once in a great while for my dell latitude model PP01L
ttstroh,
It sounds as if your audio card has died. Start over again, do the following:
1) Turn the computer off
2) Remove the audio card
3) Restart and uninstall the drivers
4) Turn the computer off
5) Install the audio card
6) Restart and let Windows install a driver or install the driver yourself by going to the cards web site and downloading.
7) Run Windows or MS Update to confirm that the most up to date driver is installed.
8) Restart the computer
If after doing the following and the card still does not load at start up very time, the card has died. Sometimes a malware program running at startup can cause these problems so make sure that your machine is clean before doing anything.
-Chris
1helpful
2helpful
Trouble on startup
sounds like alarm isnt ground properly..
Flashing, slow startup, and finally, just snow
Try resoldering the pcb, especially the heat producing components on the pcb, do it with the crt base card too, I guess this will fix this up. Good luck.
Top ASUS Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
Paul Bade
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
