We suspect it was caused by the difference in voltages. Can I get it fixed? Cant bear the thought of throwing it away as new as it looks
I will assume that you were not using a step-down transformer (240 to 120 volts).
So what may have happened?
1. The phase board burned out.
2. The stator burned out.
3. The armature burned out.
4. The line cord and/or plug failed.
It could be one, all, or any combination of these things.
A solution is to simply convert the mixer to 240 volts. This can be done by replacing all four items above with the 240 volt versions.
If I were doing this here in the U.S., Ebay would be my source for the parts.
You can find a Service Manual which covers your model (even though it may net say so) and shows how it comes apart at:
http://www.kitchenaidparts.eu/documents/pdf/service-manual/classic-svc-manual-new-email-version.pdf
