SOURCE: the Washing Machine fills and then empties with not running a wash cycle
possible a pressure stat fault. some pressure stats have a too high water detector which turns on pump
SOURCE: washing machine does not stop filling
Does the machine start working normally after turning the wash cycle manually ?
SOURCE: washing machine wont fill
hmmm...wool requires cold water...I'm guessing that first the hot water and now the cold water solenoid valves have become clogged with sediment. test by turning off water. then loosen the hose connection to each inlet in back of washer. then slowly open water valves and let water pour into wash tub if hose will reach, otherwise pour into a bucket. if water comes out of hose, then look for metal screens at hose connections to washer and clean those. if still no water through solenoids (after re-connecting water hoses) then may need to disassemble solenoids and clean those too.
SOURCE: Washing machine fills in the water but does not start the wash cycle
The fact that it does not fill completely can be related to a problem with the water-level switch, that regulates the water level.
See from Repairclinic:
"This switch is
usually a diaphragm device with a small, clear tube attached between
the switch and the bottom of the washer's outer tub. As the water level
in the tub increases, the pressure on the air in the tube increases.
When the pressure reaches a certain level, it activates the switch,
shuts off the water, and signals the timer to begin the agitate cycle.
If the switch is defective, it may prematurely signal the water to shut
off. If so, you probably need to replace the water-level switch."
However, when it is only the switch the mashine usually completes the cycle, but with less water than normal.
A possibilty is that either the timer is faulty or there is a problem with the water supply.
Check that water is coming from water supply with regular pressure, and that hoses back there are not obstructed.
More likely you will have to replace the timer.
See again from Repairclinic:
"When the cycle doesn't advance, it's probably the timer or a cold-water supply problem:
You can find parts at the following websites, you need to input your model number. If the part is not listed contact them.
Repairclinic
Partselect
Don't forget to rate the solution.
Many thanks.
