SOURCE: machine wont stop filling with
Same thing happened to my ASKO W600. Sounds like the water inlet valve is blocked or broken so therefore can't stop the flow of water coming into machine. Check it out and replace if necessary.
SOURCE: replace drum bearing ... in a ASKO W6551 step by step
you need to remove the drum start at the front remove front panel,four screws 2 under front,1 behind soap drawer and the one near the filter,next take door off 4 spring clips on the next panel plus screw on door lock,remove door lock,then undo clamp band,bolt at bottom and remove counter weight panel (heavy).remove stainless steel inner panel,use a screwdriver to loosen,from the back remove drum pulley.the drum will then pull out.replace vseal and bearings.hope this helps
SOURCE: Asko Front loader washing Machine
This is not a good news. This is an indication of an internal failure. If the pump has blocked and the thermal overload has gone open circuit,
just remove the blockage from the pump, the module and the pump should
still be okay.
If the pump windings are water damaged, the pump will
quickly overheat and cut off again. The pump must be replaced in this
case. The electronics should still be okay.
However, on most cases, this error message indicates Faulty pump or a faulty pump and board.
Let me know,if needed further assistance.
Hope i helped you.
Thanks for using ' Fixya ' and have a nice day!!
