Ovens Logo
Gary Clevely Posted on May 29, 2017
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Our model C968-69974-2 control panel Flashes 888-888 when buttons pushed and clock reads 12:24 and flashing but then continues to keep time. Sometimes,with luck can get oven etc to work. Suggestions??
Greg P
Level 3:
Master:
  • Master 538 Answers
  • Posted on May 29, 2017
Greg P
Master
Level 3:
Master:
Answers
538
Questions
Helped
154155
Points
1665
12:24 probably means choose 12 or 24-hr format.
Jenn Air gas wall oven turned off while baking and won't stop beeping about every half hour. If I try to reset bake degree, the bake light goes on, then off and it beeps again. Model # jgw8130ddb
Oven keeps beeping:
As there is no reprogramming of most control boards try this, disconnect the power and wait 30 seconds and then reconnecting the power.
If it's an "F1" fault code this generally implies an electronic oven control (EOC) failure. Disconnect the power, wait 30 seconds or longer and then reapply power. If "F1" returns upon power-up, replace the electronic oven control.
The oven control can be accessed and replaced from the rear of the control panel.
NOTE:Disconnect the power cord from the power source before removing the panel from behind the console.
If its an F2 ERROR CODE, The F2 error indicates an open circuit in the oven temperature probe.
if Your range has a resettable thermostat in series with the oven temperature probe. If this thermostat opens the clock will display F2 and the oven won't heat.
You can reset the thermostat by pushing in the reset button on top of the thermostat.
Some ovens have an alarm that will beep continuously every six seconds to alert you that the oven is still on. Usually, a kitchen timer that you have set will cause the beeping, but occasionally it can be an error with the oven's settings. If it is the kitchen timer, you can simply push the "Kitchen Timer On/Off" button to end the continuous beeping. If that does not stop the beeping, it is probably beeping due to an error. You can turn the continuous beeping off but you may still need to troubleshoot the issue that is causing the beeping noise.
Read more :
Every time I use th oven, why does it beep for a day or two going from one settin to another?
Oven keeps beeping:
Read more :
http://www.ehow.com/how_12086370_ge-oven-stop-beeping.html
2answers
Built-in oven-- clock unresponsive
You do not need the clock I removed it and wired the oven direct.The wires are easy to get at when the front panel is removed. If you look at the manuals on line they will guide you with the correct wires to use
Microvave control panel is locked and only shows 888. How to I unlock the control panel. I have tried plugging and unplugging it.
Hi and welcome to FixYa, I am Kelly
I really wish you had provided a make and model number but.. here goes without a model number.
888 is what happens when you lose power on many microwaves. You simply push stop / cancel then you have to set the time by pushing CLOCK enter current time and CLOCK again. You should be able to use your microwave normally after doing this.
If this does not correct your 888 problem please respond with a make and model number so I can look up your model.
Thanks for choosing FixYa and Happy New Year,
Kelly
Jan 01, 2011 • Ovens
3helpful
AEG single oven - clock runs for 12 hrs , buzzes and goes back to 12 o'clock - if set timer and check time remaining, it buzzes and jumps to clock setting loosing time remaining. Buzzer sounds ''hoarse''.
you must setting the count down timer instead of time of day. to set time of day. press centre button 4 times lamp flashes in bottom righthand of display. use + and - to get correct time after 10 secs time will lock in. to check you have not set count down press centre button 3 times lamp flashes top right corner of display if not at 0000 use - button to get to 0000 leave 10 secs then should revert to time of day. also check you have not entered cooking time. press centre 1x this also should read 0000. hope this helps
While working near my Jenn Air Oven (Model JJW8527CAB) the function keys were possibly touched and the oven started displaying F7 error code and is continuously beeping. Pressing Cancel does not help....
Oven keeps beeping:
Read more :
3helpful
3answers
F7 code keeps flashing on upper oven, nothing on keypad works
A function pad is probably stuck.
Push all buttons several times each. Often this will clear a stuck pad.
If that does not work replace the clock.
Time flashes ...No other electronic button function
You may have the dreaded F7 problem. Go to the following link:
http://www.fixya.com/howto/h155060-dreaded_f7_error
Please let me know if this works for you. I have shared this fix with over 1600 folks and most report success. You can email me at [email protected]
Regards,
Charlie Popeck, P.E.
Consulting Engineer
Top Ovens Experts
ZJ Limited
ZJ Limited
john h
Are you an Oven Expert? Answer questions, earn points and help others
