The rain fly on this tent doesn't drain well because of the horizontal poles along the edge of the roof of the tent. consequently the water pools above these poles and the pressure makes the fly leak. When it is really burdened, it can collapse the tent and bend the poles. I have to get up frequently on rainy nights and push the water off the fly. Otherwise it is an amazing tent. The high roof is great, no bending over, and there is plenty of room to move around and organize your stuff. the row of windows on the front provides an amazing view and lots of fresh air. It's almost like a screen house instead of a tent.
did you ever find your poles? I had the same problem and need the roof pole as well please let me know if you found them.did you ever find your poles? I had the same problem and need the roof pole as well please let me know if you found them.
You can't post conmments that contain an email address.
Re: I need new poles for Swiss Gear tent # SG33071F
Go to Home depot and buy a tube that fit the pole. Cut it into 5 or 6 inches for the broken areas. It costs me less than 2 dollars. Let me know how it turn out on yours.
Unpack your tent supplies.[1] Once you've found a good area to set up camp, it's time to unpack your things. It's a good idea to pack all of the parts out at once. Assembling your tent will be fastest if you don't have to unpack each item one at a time. Keep all parts nestled in one place so you can keep account of everything. Because the list of supplies depends on the specific type of tent you're using, here are a few different types of tents you can consider:
A-Frame tents are the most typical and common type of tent for personal use. They're the easiest to erect and usually come with extras like a rain-fly and weather tarp.
Tunnel tents are different from typical "A-Frame" tents because they are structured by two long poles that both run the width of the tent. This creates a wider interior with more headspace. However, they're not nearly as stable when it comes to wind.
Dome tents are generally the largest, and usually reserved for larger groups in camping. Although they're quite a bit bigger, they're generally very easy to pitch.
Lay down a ground cloth.[2] No matter how much you clear the area, there may still be twigs and other debris that could puncture your tent or make the surface otherwise uncomfortable. A ground cloth should be big enough to encompass the space of at least most of your tent. The added cushion of a ground cloth will lead to a more comfortable rest.
Insert your tent poles through the frame.[3] Once you've gotten all your tent parts out, slide the support poles through the body of the tent. Lie the tent frame out. That way, you can make sure you're sliding the poles through the right slots. This is arguably the most time-consuming part of tent assemblage, but it's very straightforward.
In the case of a "tunnel tent", make sure the poles are parallel from one another
Raise the tent. If the support poles have joints, make them rigid. The poles are going to have a pre-set frame to them for the main body of the tent. Help the tent up by lifting parts of it. The poles should hold the frame in place. If not, secure loose parts of the poles or extend them as needed.Hammer in your tent pegs.[4] Using a mallet or a nearby rock, take the spikes that come with your tent and hammer them into the ground. This will stabilize the tent and make sure it doesn't move around. If you don't have tent pegs for whatever reason, you can improve by using sturdy sticks and pushing them into the soil.Set up the rain-fly.[5] It's important to keep in mind that tents on their own are usually not waterproof. This is where the rain-fly comes in. A rain-fly is an additional piece you set overtop the tent. There should be something along the line of latches on the roof of your tent to secure the rain-fly in place. Even if you're pretty sure there will be no rain, it doesn't hurt to install it nonetheless. It will ensure all of your tent equipment stays in one place, and prepare you for unforeseen rain showers.Move your things into the tent. Once the tent is set up, you can equip the interior. Because there isn't usually much space in a tent, you should decide which things are alright to store outside, and which things should be kept inside. Sleeping bags are an obvious must in your tent. Crates and hard-cased storage can be left outside.
If there's a risk of bears in the area you're camping, it is strongly recommended you keep food out of the tent. If a bear comes, you don't want him rummaging into your tent because he picked up the scent of granola.
Select a flat camping area and clean the area of sticks and rocks. Remove the tent from the bag and spread out the tent body with the floor on the ground. Assemble the tent poles by connecting the attached sections at the ferrules. Set the poles on the ground and separate by size.
Locate the three long sleeves on the tent body. One sleeve is horizontal over the screen room and the other two cross the main tent body to create an "X". Locate the three long poles and slide one through each sleeve. Place the corresponding pins in the end of the poles. The poles will flex and erect the tent body. This step is best attempted with two or more people.
Attach the clips to the exposed sections of the tent poles. The clips are attached to the ten fabric and will add rigidity to the tent. Locate the next largest pole and insert it through the sleeve on the screen house. Locate the metal grommets where the screen room meets the main tent and place each end of the pole in a grommet.
Locate the two smallest poles. These are for the side rooms. Insert one pole through each of the side room sleeves. Attach the ferrule of one steel pole to each end of the side room pole. Insert the corresponding pins in the end of the upright poles to support the side rooms.
Pull on each end of the tent to ensure the floor is tight. Use a rock to pound stakes through the ground loops on the tent. Place the floor mat in front of the screen room door and use stakes to secure the mat to the ground.
Place the fly on the tent and make adjustments until the shape of the fly matches the tent. The fly will only cover the top of the screen room and the entire body of the main tent. Locate the D-rings on the base of the tent and attach the fly hooks to the closest rings. This will tighten the fly to the tent body.
Locate the guy ropes on the fly. Pull the ropes to the ground at an angle and pound stakes through the loops to anchor the tent to the ground.
Peg out 2 back pegs of inner tent. Peg out 2 front then side pegs. Place smaller pointed pole through hole at bell end of inner tent from inside, longer pole through hole at front.Fit protective bases to each pole. Top pointed poles with separators. Assemble roof pole, put through loop and over separators. Throw outer tent over from bell end (needs 2 people) then carefully lead towards front til holes in roof match - back hole first. Fit rain hoods front and back. Peg outer tent from bell end first then back corners, front corners then sides. Place porch poles through holes at front of porch, zip door sides down with one person holding poles upright and taut and peg out door. Peg sides all along making sure they do not touch inner tent. Fix guy ropes.
Are the are pins attached to the pole attachments tabs at the corners along the bottom or farther up the sides at the corners? If they are at the corners a few feet off the ground, they are probably for the rain fly. If they are ground level they could be for an attachment that may not come with your tent like a vestibule. They could also be used for securing the tent after it has been rolled up. In either case here is a link to your tent that might be helpful. Just scroll down and click on the product manual link.
