SOURCE: Opening up Speakers
i it wood or plastic? if you cant easily pry the 'screen' in front off and there are no screws, your best bet is just to find a new speaker box to put new speakers in... only way to open it is to tear it apart, unfortunatly.. if you do decide to open it, CAREFULLY cut the screen off with a razor or exacto knife, once inside you'll know better what your dwaling wiht...good luck
SOURCE: 2002 Grand am gt monsoon, hook up rear aftermarket speakers
You have to test them, either should work fine (as in use either pair) if that doesn't work connect one pair at a time and listen for the difference, one pair might be for factory midrange and other for tweeter.. there are two different wiring configurations...
SOURCE: my mordaunt-short avant 908i front left speaker
I had similar problems my tweeter was blowen and it had to be replaced... I actually blew the speaker many times using a NAD amp as there were spikes coming from the amp. I changed the amp to a Marantz PM7200 and have had no problems since.
SOURCE: i HAVE THE MTX TP112 SPEAKER, THE HORN TWEETER
It is a one piece horn need to replace the whole thing. These are not like normal PA speakers where the driver can be unscrewed from the horn lens and replaced.
SOURCE: Paradigm Monitor 9 v4 tweeter not working.
speaker is must likely blown. check to see if another tweeter works at that connection.
